All at the sudden 0dB on my test record cannot be regarded as 0dB, and because I displayed only one version of all 4 tested versions, this would implicate that I haven't tried more than 1, the displayed amplitude levels in your posting #29 are suddenly irrelevant, wet playing ruins a disc but wet cleaning does not, and so on and so on.
For reasons already set out, your 0dB has no meaning without a reference level which we do not know, Hans. In one plot, IIRC, you manually inserted a reference level overlay, deleted other aspects which would be expected as signatures of vinyl playback such as harmonic distortion spectra. Whilst I'm sure of your good intention, there is no way to verify the absolute levels of your plots. In fact, most of them lack characteristic features one might expect from normal vinyl playback, and are, as such, abnormal.
The absolute level of the noise floor is irrelevent, rather the contrast between ultra-low friction and normal playback. But, in fact, you did not measure friction coefficient, Hans. And your plots, from what we can tell, lack the characteristic attenuation of cart-arm resonant peak associated with reduction in friction coefficient. So there is no evidence your tests involved reduced friction at all, we simply do not know....... if you PM a link or post the raw recorded files, I'm more than happy to analyse them for the lf signature of reduced friction, I predict that would reveal the truth of the matter?
In fact you told us you had not repeated your test, you just repeated analysis - whereas I have repeated my tests with similar results across test discs many times over the years, to the point where there can be no reasonable doubt, including on 3rd party recorded test files which support my results, as already presented on this thread.
Furthermore, each repeat test consumes a test disc. It is typically ruined afterwards by permanent deterioration of surface noise for dry playback, a matter which you have either not tested or are silent on, Hans.
1) Sampling frequency 96Khz, to prevent aliasing
2) FFT of 65.536 points, giving a filter bandwidth of 1.5 Hz and a sampling time of 0.7 sec per FFT.
3) A Hann Window to supress side lobes of a known fundamental in amplitude making it possible to have an absolute reference to the measured noise (in my case 0dB @ 1Khz)
4) Averaging of 32 FFT calculations to flatten the noise spectrum.
The total sampling time therefore is a minimal 32 time 0.7 sec = 22 sec
So the test tone has to last at least 1 minute giving you the time to properly start and stop the recording.
5) Measure the noise from the recording chain, i.e. Arm in the air, platter running. If this noise is not at least 12dB below the surface noise of your test LP in the measured spectrum, you will have to correct the measured surface noise for this extra noise contribution.
Great, that should yield characteristic looking results, similar to mine, so why not ? Again, if you share the raw recordings that should settle the matter, Hans. The plots just don't look like normal vinyl analysis, IME, wheras they should with that method - I suspect some mistake !
It is not at all my intention to prove anything, other than showing that "wet playing reduces noise" is not always the case.
There is no dispute here. For example in the case where dry playback already had friction low enough not to contribute to surface noise, as already suggested may be the case in your test, Hans. However, you did not measure friction coefficients wet/dry, Hans, which is a pity, a missed opportunity, and an oversight in the circumstances.
At first I thought I had to play forever wet, but "scraping" the LP several times while constantly cleaning the needle and thoroughly cleaning the LP on a cleaning machine afterwards seemed to have solved that problem in my case.
OK, so did you record the sample in that state, or measure friction coefficient ? Then again after cleaning ? The act of cleaning per se can alter friction coefficient, depending on method and agents Pardee JAES Dec 1981. Sometimes better, sometimes worse, sometimes no change.
So the attitude that is best in things like this, keep your mind open and take nothing for granted.
And I could not agree more with your phrase: It does not matter who is right, all that matters is to get it right.
Yup. And be methodical before even thinking your work might be valid 😉
LD
I am skeptical myself about once wet always wet being a hard and fast rule.
It typically is though, but not always IME. What's more, 'normal' playback can be restored by pretty much any agent that reduces friction, not just water, IME. No reason that shouldn't include cleaning I suppose, with the right agent and regime, as per Pardee's '81 JAES article.
LD
In thinking what I need to consider with this, just revisiting noise sources (for a fairly wide definition of noise) and so far have:
1. Noise cut into the groove from master tape, cutting amplifiers etc. This is correlated, so each play gives the same noise.
2. Noise due the vinyl. Also correlated, with good vinyl should be much lower than 1.
3. Noise due to static charge. Uncorrelated
4. Noise due to dirt. Uncorrelated
5. Noise due to mistracking. Uncorrelated
6. Noise due to friction. Uncorrelated.
7. Noise due to the cartridge/preamp. Uncorrelated.
Have I missed any?
Still trying to work out the easiest way to make a friction measurement setup. First thoughts are that a garrard 301 style idler setup would be the easiest so that you could get the platter to speed then remove drive. I'm sure I have all the bits needed somewhere...
Have I missed any?
Then again, I don't have a good grasp on the local thermal situation at the tip-record interface.
Me either that's why I threw out some kind of micro-cavitation effect. It's one thing I know that has some non-intuitive unusual properties. No idea if it applies here at all.
It certainly fits the category of "not such a clear problem when you dig into it". Great discussion, enjoy it thoroughly.
The part that has most fascinated me is how much the stylus can change the noise spectrum. If you have a large vinyl collection then one stylus may not be enough. Which just makes it more confusing why the phools still stick by MCs*. It also might explain some of the arguments people have over diamond profiles.
* I was that phool, but I am getting better.
On the manufacturing side why would there not be a standard profile for the cutter head of the lathe?
I thought there was but a matching stylus would be one play only (chisel).
Me too, this anachronistic problem is a fun brain exercise the VFA/CFA thing gets boring after a while. But then I put on an old favorite LP and I am transported to Nirvana (well not quite but you get the point). 😉
🙂 same boat. But I have the 'it just works' turntable. This is for the fun part (when I get odd minutes for that).
Has anybody ever inspected the grooves before/after wet playing by a microscope? I found here some interesting pictures:One thing to add to the list, explore thorough vacuum cleaning before/after wet play. I'm fairly sure some of the stories are based on wet play of used LP's some even with mold or heavy smoke contamination without any pre-clean. This was certainly the case with my friend. I am skeptical myself about once wet always wet being a hard and fast rule.
Incredible photos of record grooves under an electron microscope
Google gives many others, Micrographia, Vinyl Asylum, etc.
Have I missed any?
Blimey, what a rogues gallery ! Amazing it works so well in practice, which it does of course. There's also spindle bearing rumble, motor whining/cogging, platter microphony, ground hum, off the top of my head.......
There's a nuisance ranking to all of that lot. For me anything that has an audible single tone like sound, such as hum, rumble, motor noise etc is top of the eliminate list. After that, it's crackle-pop-tick, so static/dirt/friction. I don't mind white/pink noise if its quiet enough. Part of analog heritage !
Here's a repost from some idiot a few years back on another forum 😉
All good stuff. Here's a repost of a simple method to measure stylus/groove friction coefficient, which produces results comparable to JVC figures posted on Yosh's site (range c 0.2-0.55 IIRC). Stylus/groove total friction force = this coefficient times VTF. I have tested this method, as have others, and am fairly confident it is correct.
I call it 'the stopping method'.
I worked out a simple method to measure stylus/groove wall friction force using platter rotational stopping time. All that's required is to weigh the platter and measure the stop time a few times, and measure a few distances. Here's the explanation.
Firstly, a repost of the definitions from equations in post above
w(0) = initial angular velocity (rads/s)
w (stop) = final angular velocity (rads/s)
a = angular acceleration (rads/s^2)
t = time (secs)
T = Torque (Nm)
I = Moment of inertia kgm^2
F = applied stopping force N
r = radius of applied stopping force F (m)
here's the measurement method
Step 1. Determine T(b) the friction torque in the bearings of the turntable
Weigh the platter and measure the radius. Calculate moment of inertia I = (m*r^2)/2
e.g m=1.6kg, r = 0.15m I = 0.018 kgm^2
Calculate w(0)
e.g. at 33 1/3 rpm = 2*pi*33.33/60 = 3.5 rads/sec
Put a record on the platter and spin it, but do not play. Suddenly slip the belt off allowing the platter to rotate, and measure time to come to rest t.
e.g = 45 seconds
The frictional torque from bearings T(b) = I*a = I*[-w(0)]/t
e.g T(b) = 0.018* 3.5/45 = 0.0014Nm
Step 2 . Determine T(F) the friction torque due to stylus/groove contact
Play a 33 1/3 rpm record track at a known radius r from the spindle
e.g r = 0.14m
Slip the drive belt off and measure time t for the platter to come to rest
e.g. 23.5 seconds
Calculate T(F) = (I*a)-T(b)
e.g. T(F) = [0.018*3.5/23.5] - [0.0014] = 0.0013Nm
Step 3. Determine F, the frictional force
F = T(F)/r
e.g F = (0.0013/0.14) = 0.009 N
This is all straightforward to do, so I did a quick experiment. OM5E, VTF= 2.0g, I obtained the following measured values for F, based on measured platter weight = 1.6kg, 331/3 rpm, measured stop time = 23.5s (stylus down) measured stop time = 45 seconds (stylus up),
outer track r = 14cm, F = 0.009N
inner track r = 7cm F = 0.009 N
From yosh's recspecs page citing JVC and other figures, the calculated value at VTF = 2.0g should be in the range 0.0044 - 0.011N.
Multiple Friction force in N by 98 to obtain friction force in grams force.
Friction coefficient is simply F/VTF (make sure same units eg gf are used)
On the face of it, this accords with Yosh's JVC etc figures posted on Yosh's site.
This is similar to Robert Pardee's 1981 method, I subsequently discovered. Using this method, I found that friction coefficient varies greatly between different styli, especially those of different profile and 'quality', not always as you might think. Also varies critically with alignment, especially for line contact types, I found.
PS: Moment of inertia of the platter calculation above is good for solid uniform platters only. Otherwise, one has to calculate I depending on the distribution of mass within the platter. I'm a physicist, all my stuff is only good for spherical cows in a vacuum ;-0 But calculating/estimating I is not too hard with a bit of reading up for the rusty/uninitiated, and is good for the soul......
LD
There we go again.For reasons already set out, your 0dB has no meaning without a reference level which we do not know, Hans. In one plot, IIRC, you manually inserted a reference level overlay, deleted other aspects which would be expected as signatures of vinyl playback such as harmonic distortion spectra. Whilst I'm sure of your good intention, there is no way to verify the absolute levels of your plots. In fact, most of them lack characteristic features one might expect from normal vinyl playback, and are, as such, abnormal.
Posting #50, here displayed up to 2Khz, was the Original Recording for 1) the level of a 0dB test tone, 2) the noise level of a silent groove and 3) the noise of the playback chain. All 3 recordings played at the same gain level of the recording chain.
So here is the reference of 0dB against noise.
Posting #33 shows exactly this noise level, now transferred to excel together with the level of the 0dB 1Khz, the whole set now normalized to 0dB for the 1Khz test tone on the vertical scale.
From there I calculated the other lines in the figure and the dynamic range in dBA ref 0dB 1Khz.
Apart from the above, I measured the amplitude of the mono 1Khz 0dB test tone at ca. 36 um which turned out to be exactly the value it should have for a 0dB mono test tone.
So dr. Feickert did his homework correctly.
Here cannot be any possible dispute about references and absolute levels, period.
That is exactly what you see in again the Original Recordings in posting #122, only the relative differences are important, the absolute level here is not normalised and has no meaning.The absolute level of the noise floor is irrelevent, rather the contrast between ultra-low friction and normal playback.
The original recordings are in posting #122, I even showed the plot of the resonance of my arm / cart combination.But, in fact, you did not measure friction coefficient, Hans. And your plots, from what we can tell, lack the characteristic attenuation of cart-arm resonant peak associated with reduction in friction coefficient. So there is no evidence your tests involved reduced friction at all, we simply do not know....... if you PM a link or post the raw recorded files, I'm more than happy to analyse them for the lf signature of reduced friction, I predict that would reveal the truth of the matter?
I think you will have to be very clever to extract a "signature of reduced friction" from this.
Just compare posting #50 from 2 years ago with the recording in posting #122, from last week and you will notice they are the same.In fact you told us you had not repeated your test, you just repeated analysis - whereas I have repeated my tests with similar results across test discs many times over the years, to the point where there can be no reasonable doubt, including on 3rd party recorded test files which support my results, as already presented on this thread.
And to conclude, I'm not interested in friction coefficients, at this moment they just have no meaning to me.
I just wanted to check whether wet playing reduces the noise, which is clearly not always the case.
You should turn your mind 180 degrees and ask yourself "assume that all test are performed correctly, what might be the reason for the unexpected outcome" instead of trying to finding errors in the way I did the testing.
You know what test disk I used, but for whatever reason, you never told so far which test disk you used ??
Hans
Understand on the coast down. Problem is I don't have a turntable I can do that with. So need to make something out of the bits I have. When doing this some form of rim drive has it's charms.
.....1) the level of a 0dB test tone
But we do not know the absolute level of your 0dB test tone, Hans, because you either do not know it or haven't told us. Decibels are a ratio, and to be meaningful as an absolute measure, there must be a reference. There is no definitive meaning of '0dB', for the reasons already set out this changed over the years between various standards bodies. You have to know, and tell us, otherwise we have to guess.
.....All 3 recordings played at the same gain level of the recording chain.
But not at the same time, nor at the same radius on the record, and none of them with measurement of friction for correlation.
.So here is the reference of 0dB against noise
Strictly, you mean a tone of unknown level against noise measured at a different time on a different part of the record........
.Posting #33 shows exactly this noise level, now transferred to excel together with the level of the 0dB 1Khz, the whole set now normalized to 0dB for the 1Khz test tone on the vertical scale.
Trust you can see the scope for mis-assumptions here, as above.
.Apart from the above, I measured the amplitude of the mono 1Khz 0dB test tone at ca. 36 um which turned out to be exactly the value it should have for a 0dB mono test tone.
Strictly, you measured 36 um at the second attempt, Hans, and stopped. Amazing. And we still do not know what the reference level is, so strictly whether 36um is 'correct', nor what you might have measured if you checked for a 3rd time.
.I think you will have to be very clever to extract a "signature of reduced friction" from this.
If you post or PM a link to your raw files for wet/dry of the silent groove, in any lossless format, I can analyse the cart-arm resonant spectra and reveal enough of a signature to comment on the likelihood that the friction coefficient was altered significantly between your wet/dry tests.
This is because reduction in friction results in reduction in skate force, and dynamic variation in skate force is a significant stimulus for the cart-arm resonant system.
If you aren't going to provide them, just say and I'll stop asking.
.... to conclude, I'm not interested in friction coefficients, at this moment they just have no meaning to me.
You totally miss the point, Hans. The correlation between friction coefficient and surface noise is the point of interest being tested. Unless you are successful in altering friction coefficient, you will not alter surface noise via wet playback IME.
Over several years I probably went through dozens of test records of various types and from various eras. I obtained several batches of factory test records, some of which have a whole side recorded with tones for IMD tests. I believe my original post was based on one of those, for which the absolute IMD tone levels are irrelevant for the purpose at hand.
Having characterised wet playback and its correlation with friction coefficient, and the audible and measurable effects on playback, I reached the point where there was no point in ruining more test records.
As Billshurv posts, it's mostly for curiosity and interest, and, for me, understanding what other factors might influence friction, and so surface noise.
LD
Unfortunately SEM photos are destructive of the LP since only a piece is used and it has to be coated with a conductive layer. This is cool - https://www.youtube.com/watch?v=GuCdsyCWmt8
Some interesting comments I have read are that Dynagroove records were intended for a conical stylus, and, that changing from a stylus with a older profile to a modern type would show up in replay, the extent of wear in the grooves of a recording caused by previous incumbents.
For information on recent Ortofon and an old Nagaoka cartridges - frequency response graphs, tracking information etc and reviews - see
https://system.netsuite.com/core/me...ocodeaction=overwrite&addrcountry=US&gc=clear
MC cartridges are very expensive but Ortofon are still into that game.
Maybe the Nagaoka is acceptable for use with worn discs "as is".
With modern SEMs, you don't need to vapor coat or sputter with gold any more. Our company has tightened up the use of our SEM, but if I can figure out a way to sneak one past, I'll try to get some photos. This is almost certainly a mechanical effect, not chemical, but my knowledge of fluid mechanics is at the undergrad level so I wouldn't speculate as to what it is. Maybe some good SEM data will point us to the right answer.
Yes, it is cool. Stop frame animation though, wouldn't real time high frame rate be great ?! SEMs have fantastic depth of focus that optical can't touch !
LD
I'll have to think about it, but I'm wondering if I'd be able to see anything with some form of interference microscopy to elucidate anything about surface state (I'm not equipped in my lab with the right filters, but have a stage big enough that I could image select parts of a record without damaging the record), even if the spot size is large and it becomes more of an ensemble measurement.
I know people are using lasers as read-heads for vinyl, so the surface must be reflective enough to garner something.
- Analogue Source
- Reducing Record Surface Noise - I want to know all Approaches
