rAudio-1 (Arch-based music player for all Raspberry Pi's)
Oups! Sorry, forgot to mention it... So here is my setup:
RPi4 -> USB (data & power) -> Khadas Toneboard
And a few screenshots.
Hope this will help.
I am enjoyin rAudio-1
1) smooth CD playback listing to my old cd's
2) AirPlay shows the Album Art and other details.
3) Snapy interface
what i would like is a playback screen like PCP, its just that i am used to such a screen.
is there a way to mode the playback screen
1) How to remove or edit a NAS listing ? Can create but can't find remove or edit.
2) USB dac Creative Soundblaster XFi 5.1 output is very distorted. This dac works with other RPi distro (PCP/Moode/Volumio) other USB dac work with rAudio.
seems the mixer device is not found as the listing is blank.
Well here I am again, same issue (8/25/22 post) with the current version, 20230630. Multiroom playback worked fine for a while but then it just stopped working. Not sure why so as a stand alone it worked fine so I just used that. Recently decided to update both units to see if I could get things working again but neither unit would update so I downloaded/installed the current version and tried to setup multiform playback with no luck. I'm sure it's just an incorrect setting or not turning some feature off/on. Can anyone shed some light on the steps they used to enable & use multiform playback? Any advice would be appreciated.
@Raitsa I did post a requirement on the GIt discussion board just repeating it here
I need to use 7.9" DSI display by Wave Share 1280 x 400 .
unable to use the following commands on r Audo -> CD or CD.. or DIR or Lst or LIst on rAudio - Is there a work around to install the required driver.
@Raitsa did you still used it?
i sent my mp3 file with smb to the sd card. it can recognize there is a file. recognize by song counter in the top. how ever i cannot open SD card file list or USB file list. and the mp3 is not show up in no where. after added some id3 tag the mp3 show up in the artist song list.
is this expected behaviour? or it is a bug?
i already post in github and no ones replied. so i trying to asked if you are the dev. sorry for misunderstanding
