Have you ever used a damped order filter? Try adding a 2 ohm resistor on either the .18mH coil, or the 10uf cap. One or the other may improve the alignment.
That's too long for typical indoor measurements. Show us the impulse response data, which is more useful to assess the gating.5ms gate
I suspect these data are not anechoic
Whoa, you mean to tell me the measurement conditions I stated of being right next to a highway, on a 10ft ladder isn't anechoic? Boy am I shocked lol.
I didn't do them indoors. Are you even reading the posts here?
Show us the impulse response data, which would be more meaningful so assess the echoes.I didn't do them indoors. Are you even reading the posts here?
https://drive.google.com/file/d/16SpYfXZ3ELO-TEIR5DzzOMzERChXuuto/view?usp=sharing
The sharp peaks at 3.75 ms, 4.6 ms and maybe also at 4.1 ms look a bit funky. What are they? Reflections?
Could be, who knows. Response doesn't really change with gating so I'm gonna move past whatever thing you're focusing on as I don't feel you've really been reading the information provided in the thread.
Ok, you don't seem to care about your measurement data. Good luck, and good bye.
Lol sure, whatever. Thank you for leaving, you were already set to ignore and likely for a good reason. Bye bye 🙂
I don’t think the peaks should be problematic when designing a crossover. They are however to assess the system and/or components.
You ask us to rate the crossover. I’d say you don’t need the notch on the woofer coil nor the zobel (?) on the tweeter.
The proof of the pudding of course is in the eating. Build the crossover and measure the system. Then rate it yourself, I guess…
Regarding Filter:
I assume you are using LR4 crossovers, given the DEEP reverse null. LR4 gives a bump in the power response at the crossover but provides good phase matching. As I know you are interested in smooth power and in-room response, try 3rd order crossovers (Butterworth or Linkwitz-Riley). Simulate and save the different variations of 3rd order using xo points of 2000, 2400, 2800, and 3200. Now compare the Power and PIR and see which ones are getting you the best results, pick the one you like best and tweak from there. Note, however, you will not get a deep reverse null, but you can keep an eye on the phase of the individual drivers near the crossover point.
Measurements:
You have received a lot of feedback on your measurements because it "looks" like there may be issues. One way to check...wire up one of your crossovers, make sure all of the inductor DCR's are correct in VituixCAD, measure at 2m, and load the FRD into VituixCAD as an overlay. VituixCAD is very good IF you give it good inputs. If everything is good, you should be within about 0.5dB or less, between your measurement and your simulation, 20kHz down to 300Hz or so.
If things do NOT match well, then it is your measurements. If that ends up being the case, you should start a thread about the measurements and tell us more about the baffle dimensions, mic, REW settings, etc.
Measurements:
Does this help with your question about DI?Cycling through reference angles and back.
- Rate my filtering
