Questions about the Aleph 5
please refer to the attached schematic.
capacitor in parallel to all zener diodes
Thanks ZM!
also, concerning the power supply, would it be good to put a MKP capacitor (0.22-0.33uF) on the primary winding ot the tranny and two MKP (0.47-0.68uF) on each secondary winding?
I would not build a power supply with CRC or CLC filter
thank you again
don't do that with xformer
find and read Quasimodo and Cheapomodo threads here
if you are not sure in what you're doing , better don't do anything
this table is good , but as semi-patch , not proper one , made after adequate test:
Hello ZM,
PCB development is in progress, I finally decided for the traditional 2 layers!
question about the output devices (IRFP240):
- the original design has 3 paralleled devices while the modified M10 has 4 in parallel. is there any advantage to have 4 instead of 3?
- power transformer output voltage question, would it be possible to have 2x26Vac as secondary?
- 26x1.41=36.7 - 1.4 =35.3Vdc
the original A5 asks for ±34Vdc voltage rails. don't think an addition volt and a half would be a pain.
thank you
more output pairs , if you don't change anything - more heat and more grunt on 4R speakers
don't forget to alter current sense resistor group , according to number of mosfets .... in fact - that's already done on that schm you posted
for 34Vdc rails , compute AC as DC/1.25
so around 28Vac
1.41 is for lightly or non- loaded rectification/filter
Hello Diegod,
I just noticed your questions about Aleph 5 and thought I'd add my two cents because I built a set of amps similar to what you're investigating.
I built a pair of Aleph 5 mono's with 4 outputs instead of the normal sets of 3. I've biased them up a bit and have them at 600mA per device on 33VDC rails. I'm using an Antek 500VA - 25V X 2 transformer in each mono amp. My incoming AC voltage is a bit high here at 125VAC so I get a little bump on the rails of my amps. If it was more normal at 115 -120VAC then my DC rails would be < 32VDC.
I recently went through the amps and installed SJ313's for the diff pairs and cleaned a few other problems up. I posted some info about the amps with some measurements here.
Hello ZM,
as per your suggestion to have the possibility to trim the bias, is the attached circuit correct?
The 221K resistor replaced by the R150K - POT100K - R150K
is the POT correctly connected?
thank you
