Re Quasor Amp Build
Hi Guys,
Sorry for the late reply, I was away for a couple of days. I am going away again today.....Will only be back next week.....anyway so my amp construction was a bit delayed.
I will continue when I get back. Andrew I did not received your e-mail. My address is DenzylM@kentron.co.za. Please send me the circuit. can you also send me the mosfet matching circuit?
macd
will keep you posted!!!!!!!!!!
Hi Guys,
macd
someone has done this amplifier? someone to say how this sound amplifier if you like and pictures of the amplifier developed
Hello malbasicradan, have you tried this amplifier yourself? I want to build one myself. Can you attach a schematic, PCB layout and the component placement in the thread.
Thanks!
Julius
Thanks!
Julius
quazar amp
Hello malbasicradan
can you send me too the schematic and pcb layout? Also the component side to andrinonixon@gmail.com.Thanks in advance.
Hello malbasicradan
quazar amplifier
hi andrewlebon
what is the status of your amp? Is it so powerful? 😎
regards
nix
hi andrewlebon
regards
nix
quasar reply
hi nix
greetings the quasar amplifier was assembled on stage master pcb it worked first time
but the truth is i have tested it on 50 0 50 ac volts as i did not have higher voltage torroidal
transformer i now have wound my own transformer but not tested it .I built it because i liked the stagemaster sound try anthony holtons 1000 watt .
thanking you
andrew lebon
hi nix
thanking you
andrew lebon
hi andrewlebon
do you have a schematic and pcb of anthony holtons 1000 watts?pls send me a copy My e mail: andrinonixon@gmail.com and i think both amp are good sounding am i right?andrinonixon@gmail.com
regards
nix
hi andrewlebon
regards
nix
is pcb layout and the last time I did av 1200 1200w / 4 ohm power to + - 110vcc disco and go one year and failed to schedule modificato am a bit for a better stability
hi black
Thanks for the e mail. What happen to your amp today? 1200 W/ channel have a lots of power do you have a plan to go up or your going to load at lower than 4 ohms load?
regards
nix
regards
nix
hi EMIX
No i dont have but im planning for it in home use and small party that needs sound reinforcement. Also for chapel use during fiesta. What about you?
regards
nix
regards
nix
ok... i have a sound system but i can:t satisfied my power amp to drive a 2 18 inc. subwoofer so i will to trying assembled the high power amp
name..... DIRTY HARRY by sir fotios... BJT kasi ang power transistors this amp.. in this quazar i know malakas din ito but i dont like mosfet amp.... you know i am a fan of BJT....
thanks... 🙂
thanks... 🙂
- quasar amplifier by dr bora 1000 watt
