Push one speaker in, the other goes out
I have been told that if you have two cone drivers. Put them in their individual “closed” boxes. Then, wire them together in parallel. If you press cone of one driver inward, cone of the other driver, despite locating in different box, will move outward. Is this true?
Well, let's see!
Pushing the cone of one speaker will generate a voltage which will then generate a movement of the second speaker cone.
If the voltage induced current comes out of the positive terminal of the pushed speaker, it will enter the second speaker by its positive terminal.
Does that mean the second cone will move in the opposite direction to the pushed one? I think we need a diagram! :D
If circuit is closed, input terminals shorted or low impedance amplifier connected, then there ought to be some current in the circuit when pushing a cone. Voice coil in magnetic field should induce voltage (back-EMF), which makes into current as long as circuit impedance is low. The current would be such that opposes the movement of the driver that is being pushed, so the other driver in same circuit in series with the woofer ought to move opposite direction as long as enough current happens.
If push is slow nothing should happen, inductance depends on frequency. If one pushes it 1kHz fast then why not, perhaps less is fine, as long as the push is fast :) Also, nothing happens if the woofers are connected in parallel and the (speaker input) is shorted with a very low impedance like an amplifier or just cable short, it would short the other driver, all current runs through there and not through the other woofer. If woofers are parallel, leave the speaker input open.
Test rig, connect two low impedance drivers together and nothing else, they are in series now and best case scenario to make it happen.
What if you talk to the other, can you hear it coming out from the other?:)
Reactions: 2 users
If wired in parallel (assuming plus-to-plus and minus-to-minus) you'll find the cones move in the same direction. :)
However, I suggest a quick practical demonstration to prove it to yourself. :)
Dave.
Reactions: 2 users
Dave.
Why is that Dave? Since one is the generator and the other the load, the current in them runs in opposite directions.
That should move them in opposite directions.
What's your reasoning?
Jan
Dave.
Yup.
Electrodynamic speaker is basically a linear electric motor.
If you apply positive voltage to plus terminal, cone will move forward. At the same time, back-EMF is generated wich has same polarity as applied voltage.
Now, two drivers are connected in parallel, plus to plus, minus to minus.
If you push the cone of one driver in, thats backward movement and induced EMF will be in opposite polarity.
So, second driver will be fed with opposite polarity on its terminals and it will also move backwards.
But, efficiency of electrodynamic speaker is very low, so I doubt that movement of second driver will be visible.
Reactions: 1 users
This is a speaker driver interaction that I have considered before. FWIW, I doubt that the back EMF has much if any real effect for the playback of music, correct? And this back EMF is something that the amplifier sees as well. Probably of little consequence though.
Well, I've got dual 15" super high Vas, low Qt drivers in acoustically large vented boxes, but not connected to an amp and any perceptual inward movement of the top one makes the lower one move outwards and just as quick settles to rest, presumably because it's vented.
Reactions: 1 user
When I was a kid,I took a long piece of telephone wire and hooked up a pair of small speakers together,then I cupped one speaker with my hands and spoke into it,at the other end,the speaker reproduced my voice quite clearly,all the kids thought I was a wizard or something,Later in life,when we took apart our pa speakers,we did the same with the hf horns,my mate,was on the other end,awaiting transmission with the horn pressed to his ear,I decided it would be funny to dig my face into the horn and scream as loud as I can.You can guess how that went :D
Reactions: 1 users
If you push a speaker backwards (cone towards magnet system), the "+" marked terminal will become negative (relative to the other).
A similar speaker, connected in parallel, will also get that negative voltage and also move backwards.
So both will move in phase, whether forwards or backwards.
Reactions: 1 user
The OP specified the woofers were in separate boxes.
In your case the woofers are in the same box.....so, a different configuration....even though the box is vented. In that case the momentary air pressure differential is somewhat greater than the electrical drive, and thus you see the woofers moving in opposite directions.
The OP's query turned out to be more thought-provoking than it might seem, at first glance. :)
Dave.
Reactions: 1 users
Yes, pretty much inconsequential. Most amplifiers nowadays are pretty close to voltage sources, so the drivers "look back" into something that appears very much like a short circuit.
In certain cases though the back EMF can find its way into the feedback loop of an amplifier and cause some weird happenings.
Dave.
