Puresound P10 RIAA
I don't know more of how get ride the hum, now is less less noise than with wrong HV B+ so I consider conrrectly is due to the high MC+MM total gain, when arrives Bartolucci tx lets see what's happen with this residual hum but surely with other cart with less gain can't hear the hum.
Fixed hum, I use original Puresound PSU that's connected the HV with filaments: I used only the HV & other Tx & PSU for filaments so this is the noise problem, now I use also Puresound PSU for filaments & is dead quiet🙂
Ricardo, sounds very very good, seems that Guy have reason about RIAA but if you want I'm open to your RIAA fine tune
Are the same post 1
Left channel
R1 329K CADDOCK TF020R
R19 998K CADDOCK TF020R
C9+C8 .00270 paralleled .000106 = 2.806nF teflon film & aluminium foil
R17 38K9 CADDOCK TF020R
C7 .006 paralleled .0022 = 8,2nF teflon film & aluminium foil
R18 99R9 SHINKOH
Right channel
R19 999k CADDOCK TF020R
R18 99R9 SHINKOH
Thank you Ricardo
I would do the following:
R1 329K // 7M = 314231r
R17 38K9 // 2M7 = 38341r
C7 6n // 2.2n // 90pF = 8.29nF
That would be perfect admiting internal resistance of the first valve is 70k sharp... But we do not know that for sure so if you feel it is ok now, just let it be as is.
I want to reduce 6dBs with a voltage divider at the input of the Puresound P10 40dBs because the pre-pre used have 26dBs for 0.15mV output carts but my Denon DL103R gives 0.29mV.
Will be correct a voltage divider of two resistors of 1 Ohm each (Z1 & Z2) to drop 6dBs? Zload will be the Puresound.
I'm thinking to put the voltage divider in the Puresound MM not in the pre-pre MC.
My 103R have 0.29mV instead 0.25mV, there is something wrong or needs more break-in because I don't hear very well the extremes (lows and highs), all caps RIAA + interstage + outpout are teflon FT3. Sounds very clear and fast with micro-detail information but needs open more the lows & highs surely it's a break-in matter.
I connected a Salas 20dBs single njfet per channel pre-pre battery powered instead the Piccolo & the sound is wonderful so the Puresound MM isn't wrong, also connected the Piccolo to Rotel MM & sounds OK.
Surely Pass uses MC with 73dBs of gain because uses ultra low MC carts 0.1 mV or less.
