Why would Cascamite be illegal?
It's readily available here in the UK anyway. Would it be good for speaker cabinets? It's very rigid when dry, I've always imagined a soft vibration quenching glue to be required
It's made of formaldehyde
It has been 9 years. Wow. That makes me feel old 😱
I do still have several of the blocks - though they've lived at the back of my damp garage, so they're not really a good measure of how they'd behave in a home environment. I could dig them out and have a look.
Whilst I've not really done any spraying work for years I have since started using Titebond, which does appear to dry much more hard/brittle than PVA, so I wonder if that might be better.
That said, if I recall correctly, even Cascamite sunk - it was mostly a case of 2k paint working well (which is obviously nasty stuff).
Even better, I'd be really interested in seeing how they are after being in a damp garage.
I would love to find a durable high gloss finish I can use which doesn't need to be sprayed on.
I'm not sure if they have Devoe products in the UK but Tru-glaze with the 4428 high-gloss catalyst might work for you. Put it on with a foam sleeve (roller).
Tru-Glaze-WB 4428
Tru-Glaze-WB 4428
I normally just use Drydex and a couple coats of Killz.
That's definitely the easiest way to do it, and that's what I do too when I'm doing a big black sub box or something, but there is a 100% chance the seams telegraph through that.
Hmm... something is funny there. Then maybe a lower viscosity mud for a second (finer) coat.
https://www.lowes.ca/joint-compound...gclid=CKK24evlu80CFQcMaQodqOkBkQ&gclsrc=aw.ds
So is MDF 🙂
Haha true but it's cured already
Actually many of the major panel manufactures have been moving away from UF based adhesives in their products for quite a few years now - labeling them as NAUF - No Added Urea Formaldehyde
Be aware that the F in that acronym is a naturally occurring organic compound far more prolific than you might think.
I know a lot of products in Canada have stopped using it, I haven't seen any MDF that doesn't though
Where / what brands are you buying? I've worked for a commercial millwork (cabinet) mnufacturer on Vancouver Island for 23yrs, and all of our distributors now carry products by Westpine, Sierra ( now Roseburg), Panasphere, Murphy, States Industries to name the few that immediately come to mind, that offer most of their MDF and particle board core (raw or with factory " melamine" top coats) using resins not containing UF.
Granted, import plywoods and MDFs that might be found at big box retailers are another matter altogether - just try to find country of origin manufacturer name and spec sheets / MSDS info on some of those.
All academic to me, as I've use exclusively either shop grade Russian Baltic birch (5x5) or Europly / Murphy Multi-ply for all my speaker builds, and most others as well for at least 15yrs
I found a portion of this video relevant to the discussion here:
https://www.youtube.com/watch?v=ySPLBjFCf30
- Priming MDF boxes
