I updated with the latest volume control code and IR code. I also unplugged the analog board from the main board while it was powered up, I know, stupid. I now can't get the remote to work. Checked the battery and was able to check the remote with an IR code decoder, the remote is working. I reloaded the old sketch and the remote still is not working. I think I may have smoke the IR input on the Mega 2560. Has anyone had any issues like this? I will probably go ahead and buy another Mega 2560 because I want to build a second set of boards anyway.
You need to populate only the + or the -positions on both the top and bottom boards for balance to work. If you only populate the bottom board, everything works except balance.The preamp board, or gain section, is any preamp you wish to use. I personally like the Pass Aleph P gain design. The ardunio processor board has to be programmed. Easily done but you have to install the Arduino IDE software which is free at Arduino.cc
The Top and Bottom boards are each one channel which is fully balanced. If you only wanted single ended then you can used just use the bottom board, with Positive for one channel and Negative for the other channel.
couple of suggestions, write some diagnostics either as part of the app code to test the IR similar to your separate decoder or write just diagnostics for a hardware, test mode load.
Scope the output of the Ir decoder?
does your app have a boot loader or you need to erase/reprogram
Years ago I designed a portable radio/media player using a xmega, wrote the code in bascom-avr, still use it today. Left the coding dev at the NEC IR decoder and diags. It’s time consuming for me since I am not too good at coding. I used a maxim max9729 part for the channel selection, vol. tpa3100 amp, pcm2904? Si4739 radio chip, Rohm mp3 codec. been awhile. Just the other day I was thinking that a should have implemented a balance control. I can say the bourns encoders are reliable. A volume pot that does not require deoxit in its life 🙂
Good luck
Good luck
I'll look at that, should be able to scope the output after I read the data sheet. I'll through a few on my next parts order.
I would like to change the colors of the RGB LED. It currently is: Red-mute, blue-normal operation, green-standby. I would like to switch blue and green. I was able to get blue to work with stand-by, but could nto get green lit for normal operation. Where in the code does the balance R0, normal operation, get turned-on?
If you look at the first part of the code you see which pins for the Arduino are assigned to which leg of the RGB LED so it is a simple matter of changing the Name color you want. But check using the original code if the green LED will dim or not. I can't remember without looking at the code again to know, if it isn't a PWM pin then you may not want to do that, but your choice. let me know if you need me to dig into the code, too tired to look now, hard work day. 🙂
The 7-digit display listed in the BOM, SMC391LB G/W, is very hard/impossible to find/order. I found a substitute on Mouser from Wurth, 710-157121B12700
@johnhenryharris Exactly why I posted my issue. You nailed it, it was the IR receiver, thanks!I have found that the IR receiver device does not like reverse voltage or power surges. It is now the first place looks when the remote doesn't work. Plus they are cheap and easy to replace.
Good Luck.
And a little ways back in the thread people talked about using different colors for the LED displays and there were a lot of part numbers listed. The blue display in the BOM is only available from Digikey and they act as a broker for American Opto, I think it is, they are less expensive but hard to get. I ended up using a different blue display for 8 built with blue but the part was twice as much, then did a couple with red and they were way less expensive.
- Analog Line Level
- Preamp Control - Volume, input, mute, remote
