ppi pc4100 no output, help!
Success! I have sound!
one of the output transistors J108s was leaking, but not for one of the amplified channels. It was a transistor on the input board, that goes to the output rca's. I don't even use those outputs.
How could I have blown that?
All I can think of is maybe I didn't align the pin connector correctly for the input board and powered up sending a damaging signal, for example, the -13V is on pin 4, but pin 3 is +15, so could sending +15 to the jfet damage it?
Regardless, thank you so much for your help. Your webpage was very helpful, I think I'll be purchasing your full tutorial as well.
My next task will be fixing a pc2150, where the sound goes out from the left channel, and then mysteriously comes back. When it was occurring I swapped inputs and the outputs so I know it something internal to the amp. But I'll work on that much later.
Thanks again!
