darn, I got to go houston, been putting it off, since we were making progress, I'll pick back up with you on monday. Thanks, I think we are getting somewhere!
Pulled up one leg of the diode got a forward drop of .555V and 0 on the multimeter for the other direction, so I think that is okay. So maybe the cap is shorting? What should I check for next?
The cap could be shorted and any of the muting transistors could be defective (shorted/leaking from the gate to the other terminals)
Success! I have sound!
one of the output transistors J108s was leaking, but not for one of the amplified channels. It was a transistor on the input board, that goes to the output rca's. I don't even use those outputs.
How could I have blown that?
All I can think of is maybe I didn't align the pin connector correctly for the input board and powered up sending a damaging signal, for example, the -13V is on pin 4, but pin 3 is +15, so could sending +15 to the jfet damage it?
Regardless, thank you so much for your help. Your webpage was very helpful, I think I'll be purchasing your full tutorial as well.
My next task will be fixing a pc2150, where the sound goes out from the left channel, and then mysteriously comes back. When it was occurring I swapped inputs and the outputs so I know it something internal to the amp. But I'll work on that much later.
Thanks again!
Thanks again!
The +15v would have damaged it if one of the other terminals was at ground.
The gate acts like a diode. Applying too much positive voltage causes excessive current flow which will cause it to fail.
- General Interest
- Car Audio
- ppi pc4100 no output, help!
