Phonic Powerpod 740 problems
Hi everyone,
I've managed to repair my 740 with the assistance of the contributor ( ShorBird ) who posted the repair kit details. He was able to mail me the schematics of a similar model.
In the end, I worked through the circuit and replaced everything that had blown - not just the bits in the kit...
I took all the transistors and diodes out and tested them separately - then I replaced the ones which tested OK to be sure...
I still have no idea what caused the problem - the circuit seems to be a reasonable design and has all the obvious protection in place, etc.
I had to replace the following parts:-
The pair of IGBT switchers
The four driver transistors
( 100Volt 1 watt TO-92 - 2 NPN & 2 PNP )
The four transistors in the PWM feedback loop
( 60 Volt 300mW TO-92 - 2 NPN & 2 PNP )
The 15 volt regulator on the startup supply ( 7815 )
Plus all the diodes in the kit
All the small transistors are hard to get, but if you look for the data sheets on the web, they aren't anything special.
I replaced them all with generic parts which I could buy easily
I confused myself by looking for DC on the output fuses before realising that they are in the AC lines from the transformer...
Total cost of the parts was about £10 and the unit is now 100% OK.
Hi everyone,
Phonic Powerpod 740
Hi
Please could I have a copy of the schematic?
Ian
Yes I could, but it is 3,52 Mb large. Maybe I can sand you only schematic . Full service manual have 45 pages.
Regards zeoN_Rider
Hi
Ian
Hello there,
Could you send the parts "System Block Diagram" and "Digital Effect Schematic" of the Powerpod 740 Mixer Service Manual to wplco@lykamspam.pl? There is a problem with DSP and an electrician wants the schematics to repair it.
Regards, DJ TrueBeliever.
Could anyone mail me the schematics (or preferably the complete service manual) too?
I was given the version with a switching power supply, som som copnent have already been removed, most likely because of short circuit problems.
Can anyone help?
regard ARie (neeby)
Can anyone help?
regard ARie (neeby)
I have a 740 with the SMPS blown - the IGBT's are both dead short.
Can anyone let me have a copy of the schematic before I fry the replacements?
Does anyone know what's in the 'official' repair kit?
Thanks, Graham.
Could you repair the amp and what is the most likely cause of the blown smps?
I have an similar problem
If anyone has schematics or service manual for the Powerpod 740 with analog PSU could I have a copy, please? rguitar(AT)hotmail(DOT)co(DOT)uk
If anyone has schematics or service manual for the Powerpod 740 with analog PSU could I have a copy, please? rguitar(AT)hotmail(DOT)co(DOT)ukMany talks doesn't works !
Hi , I just kiding.
I have full service manual in PDF file format !
Regards zeoN_Rider
PS. I worked in PHONIC Service Depatment in BELGRADE Serbia .
- powerpod 740 help needed
