I hate to disagree with you, but I can read a schematic. The 740 doc I was sent has a primary transformer based power supply board. AC Line voltage is applied directly to this transformer. There are various windings on the low voltage side that go through full wave bridge recitifiers and are filtered to produce the low voltage power side.
The system I am looking at has TWO separate boards, one for the power supply and another for the two audio amplifiers. The power supply board is clearly an implementation of a switching power supply. No main transformer, big honking caps and inductors, and high-power FETS. The board layouts do not match the pictures or schematics in the manual, and the part identifications do not correlate at all.
The silkscreen on the power board of my unit has different connecters labelled for the 740 AND the 1062. In my case the 740 connecters are implemented and the 1062 connecter spots are empty.
The two FETs I pulled out of the power supply (labelled Q902 and Q905 on the board) are part number G4PC50W manufactured by IR. These semiconductors are commonly used in switching power supplies. The part number and component numbers are not referenced in the schematic or parts list of the 740 rev 1 or rev 2 manuals I have secured.
I exchanged emails with a guy who supplies some Phonic manuals (that I found on this forum), and he confirmed that the 740 Deluxe and 1062 Deluxe share a common base and have a diffent service manual from the 740 or 740 plus series.
I'm still just trying to get hold of the correct manual or schematic before I tear too much more out of my unit.
Thanks for your responses, I'll keep you posted as to how I do.
Bill
