Hi An--T,
I want to use 55 0 55 10amp transformer but thing is that, these caps are the only available here in market.
55-0-55 will give ~+-81Vdc when fed with nominal mains voltage.
What overvoltage can occur on your mains?
in the UK we commonly use 230V transformers on 240V mains that can rise 6% to 254V.
In any case even with +10% on mains supply to nominal you can use >=100Vdc capacitors.
Hi AndrewT,
Thanks for the reply
The mains here is also 220V. Can I use 125V instead of 100V caps?
Always alright to use higher rated voltage caps.
Like 125 V in place of 100 V.
In fact most higher voltage caps are better in quality = bigger.
What we should be careful is not to use too low voltage caps, when the margin they can be destroyed is not so big.
anybody can share pre amp to fit nmos300, nmos200 if possible with bass mid hi control,thanks
engel dela pena said:anybody can share pre amp to fit nmos300, nmos200 if possible with bass mid hi control,thanks
hi
engel dela pena
try this one
http://sound.westhost.com/project88.htm
regards
ravslanka,
good day have you tried already this one?how about elliot sound bridge adapter is this good for nmos?
engel dela pena said:ravslanka,
hi
engel dena pena
yes iam using that for my actrk 400 and nmos200 (both 220/247 package ) without balance it is workinng fine.as far as bridging is concerned better ask mr quasi.
wishing you and all the guys prosperus and happy new year.
fellow diy'rs,
anybody who can share,
bridging this nmos,
hybrid nmos,
any one who has knowledge please share,
please
please see this thread
hhttp://www.diyaudio.com/forums/showthread.php?s=&threadid=115614&highlight=grounded+bridgeelp us workhorse .
please check this crown bridge tech site
http://www.crownaudio.com/amp_htm/ampinfo.htm
bridging this nmos,
hybrid nmos,
please
the idea was bridging two nmos module to achive more power ,sharing the current of the output transistor,sharing current and stress
a hybrid nmos
a hybrid nmos
improvement Nmos 350
Hello,...
Actually Im modify Nmos 350 for HIGH Ourput Power, Class AB + B Output Stage , VI Limiter, Clip, Signal, Protect LEDs, Rails 130 V +/-, 20 Mosfets IRFP 460 each channel.....
I think I need about 2 - 4 weeks to finished PCB
Hello,...
Yes I want....
I have finished schematic today for new HIGH POWER Nmos and will design next week PCB.
I can use autorouter but I think is not good idea, better I take time for good pcb design
- Power amp under development
