Hi Quasi,
I am talking about a pure P-channel of course, If not, we should start another thread. As you said, its not quasi.....
Hi Quasi,
About your protection units :
In your soft-starter circut, there is a DC out (~28V if I am not wrong) Can this be tapped as the power supply for the DC detector (24V as you said) ?
Tks
Tks
Hi Bigpanda,
The auxillary voltage from the soft start board is intended to provide power to the DC detectors as you say. It can also be used to provide power to other things (LEDs etc).
Note the AC source for the soft start must come from a seperate small transformer and not from the main power amp transformer(s) and the gnd from of the auxillary DC supply must be connected to the central audio ground.
Cheers
Q
Cheers
Q
Re: NMos200 pic
Nice work Raj, glad you like it. Make sure you have good ventilation for the TO126 transistors and the small heatsinks mounted underneath.
Cheers and happy listening
Q
RSK said:Build NMOS200.
Sounding very good.
IRFP250, KSE340/350 used.
Cheers....Raj
Q
Thank you Quasi!
Yes, it is very nice to listen.
Very good bass and clear sound. Soundstage and instrument separations are incredible.
BTW, the heatsink is barely warm. Is it a good idea to increase the bias? How much more can I go?
My next project is the NMOS400 which I requested from you.
I have some fifty pcs. of IRFP452 in hand.
All the components are FOC. hehehehe!
I got it from old industrial equipments.
Cheers and keep you updated.
Raj.
Raj.
Hi Quasi,
Tks for reminding. I 've noticed it first time I saw the circuit. If yours had been available earlier, I would not have to clean up my mess I am in now, sob.....
BTW, as I said, as I am trying to clean up my mess, I had been looking for a 20V transformer but seems rather difficult to find. What if, just if, I had to use a 18V (25.2v after rectification), do I have to change any component?
bigpanda said:Hi Quasi,
The DC detect circuit is drawn showing a 24 volt relay so 25 volts DC will be fine. You could also run 12 volts to the DC detectors and use a 12 volt relay. The timing will be different but that's not overly important.
Cheers
Q
actrk600
quasi,
good day,
i'm verry happy with this amp actrk600, i use c1845,c546/556,mje350 & irf460 6 pairs,supply 54-0-54-62(not rectified)
can i use 1000w speaker?crown 18'' dual magnet for my sub?
quasi,
good day,
Re: actrk600
Sounds like a good plan. Your transformer will give you rectified and filtered rails of +/- 75 volts for the main rails plus about 86 volts for the auxillary supply and this is perfect.
With a good power supply You will get about 550 to 600 watts into 4 ohms.
But all the information about the Actrk600 is in another thread. This link takes you to that thread and a build by DanielJ http://www.diyaudio.com/forums/showthread.php?postid=1303249#post1303249
Cheers
Q
engel dela pena said:quasi,
good day,
Cheers
Q
Hello, Quasi. I preformed a search with keywords "Nmos200 BOM", but didn't found anything like this for any of the Nmos amps. Do you have such a bill of materials, and if not - could you please comply one using your schematic design program. Thanks. 😀
kalmara said:Hello, Quasi. I preformed a search with keywords "Nmos200 BOM", but didn't found anything like this for any of the Nmos amps. Do you have such a bill of materials, and if not - could you please comply one using your schematic design program. Thanks. 😀
Kalmara,
quasi posted a "Cost Estimate" in Post #141 which is as close to a BOM as you will find thus far. Please be aware since quasi posted the "Cost Estimate" the NMOS200 (TO-220) variant has been posted which the "Cost Estimate" does not account for nor the corrections or refinements that the NMOS350 has had since the "Cost Estimate", i.e. different PSU voltages, usual corrections, NMOS500.
I hope the initial "Cost Estimate" quasi posted will serve as a starting point for your build of the quasi NMOS amp.
Regards,
John L. Males
Willowdale, Ontario
Canada
24 May 2008 (17:05 -) 19:08
Official Quasi Thread Researcher
P.S. Sorry folks, but I have been dealing with a number of, and continue to, crisis the last few months. jlm
keypunch said:P.S. Sorry folks, but I have been dealing with a number of, and continue to, crisis the last few months.
John, I hope you're going along well!
Sebastian.
hi quasi im a newbie and have build your nmos200 with irfp450,mje340/350 and supply of +-43v dc what is its output
and what if i increase the value of r3 e.g 82k
Hi Ravslanka,
At best your amp module will deliver about 70 watts into 8 ohms and about 130 watts into 4 ohms depending on the size and quality of your power supply.
R3 in part sets the input impedance and should not be changed. It has no bearing at all on the output power.
Hope you enjoy your amp.
Cheers
Cheers
Hi Quasi,
Sorry to bother again. I have come across some soft-starter circuit saying that the delay time can be order of seconds. I am quite stuck by this kind of timing. The resistors will be heating up a lot for delay time of seconds, won't they? What's the delay time for your circuit then? Because I am integrating it into a circuit with a speaker protection which has 1. a delay time on, 2. DC detection and 3. a thermal detection . If your delay time is longer than that of the speaker protection, it won't mean anything at all (I mean it should be shorter than the speaker protection delay, should'n it? Or it won't be serving its function? )
Some said that it should be in terms of 0.2 - 1 sec. What 's on your mind about this? It won't matter if it is 0.2 or 0.5 sec. But I think it does if it is 0.2 or 2 sec.
Tks
Tks
soft start is to allow toroids and big EI to establish flux.
This takes just a few cycles from off.
The delay on the resistor bypass is effective even if set to as low as 100mS.
It does not need to be 500mS or 1S or 2S.
Hi BigPanda,
AndrewT is quite correct. My softstart delay is about 250mS and seems to do the job. Too long a delay could as you suggest be a problem for the resistors, but this would depend on the size of the power supply (including capacitors) you were trying to start up.
Cheers
Q
Cheers
Q
hi quasi thanks for your support and providing such a great amp which works on the first attempt
i will be posting the pics soon
one more question i want to build your n channel bipolar350 but
mje15030/31/32,33/34,35 are not available here so may i go with mje340/350
Unless it's a class A amp essentially the same energy will be taken up by the soft start resistors independent of the time they are switched in if the time is long enough for the caps to charge up fully. The energy dissipated will be the same as the energy stored in the caps when full. (When charging capacitors full through resistors the same energy is lost in the resistor as is stored in the cap when full)
I wouldn't recommend switching out the resistors before the caps are full, the flux can't reach steady state while the caps are clipping the voltage waveform.
use a second slow charger with bypass in the secondary if smoothing capacitance peak/sustained current is worrying you. This better suits a power thermistor to maintain a good current flow as the caps charge up.
Save the slow start for it's specific purpose. To get the transformer started without requiring a (useless) enormous fuse value.
- Power amp under development
