I made a compact version of the post-notch preamp. Same box (enclosure) as for notch, powered by external batteries. Gain is selectable by jumper, 1x or 100x. The PCB has two versions, one for single op-amp (OPA627,827,828, etc) and another for dual op-amp (OPA1656,etc). On the picture you can see boxed OPA827 with bypassed input/output caps (4mV output dc @40dB) and unboxed OPA2141 version (waiting for OPA1656). Second picture captures OPA827 output noise (amplification 100x) , input impedance is 50R.
Almost finished voltage divider, AAA battery holders are on the way, till arrive I made a battery pack (white color on the picture).
The front board holds the divider/attenuator, mosfet SSR, mosfet driver while the rear one is a protection logic/driver.
Jan, TY.
There's one thing I regret, I should have used BNC connector, it's far more better than RCA.
Yes my passive twin-tee is with BNC ;-)
Jan
- Design & Build
- Equipment & Tools
- Power amp measurement system
