Hey Ben
Looking good, you will have plenty of time to complete your board as Edcor tend to take a while on the transformers.....
Where are you planning to get your socket from?? I got mine from these guys Pacific T.V. - Vacuum Tube Sockets hassle free
What sort of case are you planning?
Cheers
Cheers
Hey Ben
Cheers
I also have a Millett MOSFET-MAX to complete as well, so I'll be turning towards that little guy soon. Not sure where I'll get the sockets, there are a number of sources. Antique Electronics Supply is in Tempe, AZ and I'm just next door in Mesa, so I might stop by there and check them out.
I am planning a custom case. I've got some RTiA5's in Cherry from Polk Audio, and I'm thinking of pairing this amp with some RTiA1 or A3's. That being the case, I'd try and mimic some of the design elements, the curved cherry wood finish.
Well, the MOSFET-MAX is almost complete, just waiting for a couple hardware pieces to complete the case.
However, my Edcor transformers have arrive and they are beautiful. They still smelled of the lacquer paint. So, I can switch back into my "Engineer's Amp" mode. I guess I need to design the case to get started with some of the remaining bits and pieces.
Got my Edcor transformers. They are beautiful.
I have also finished my MOSFET-MAX with good results.
Now, I'm back in research mode. Looking for a suitable preamp for my engineer's amp and sketching up some design ideas for the case.
Very cute! What cans are you driving with that?
Same here.
jeff
A few years ago I discovered the Conn organ amp that used 7027 output tubes. The power transformer is the ultimate in simplicity: 2 black wires 2 red wires and 2 green wires; plus a white wire for the ground shield. The filament winding is easily capable of handling 4x 6550s plus another 1.5 amps for the front end; the power winding is of course a voltage doubler type; quite comfortable running 1200 uF filter caps, and providing about 460 V to the plates. The output iron features 4-8-16 ohm output taps and gives the Citation 5 a SERIOUS run for its money. Vintage Conn Organ 2 Channel Tube Amp Amplifier from Deluxe Theater Organ | eBay (got it for $95) You have to get a second one to get two outputs; this one completes my set so happy bidding!
Oh and BTW check these guys out Tube Amp Chassis DIY 13x10x2 Aluminum Project Box Enclosure Stereo Amp Preamp | eBay Been using their chassis for quite some time now.
What I do is to pull all of the parts from the Conn amps (transformers. fuse, sockets, resistors, diodes) and install them to the new chassis. Then new caps and modern input/output terminals and an IEC power entry A decent set of 6L6's will do about 25-30 WPC with the self biasing circuit. Upgrading to a fixed bias and a 5-20 front end ups the power to 50WPC and will give a Citation 5 fits in a shootout at a fraction of the cost.
First power on...not quite there yet.
I powered up my amp for the first time today and I've got problems. I am fairly new at this and could use some assistance. When bringing up the bias to a reading of 400mV I get a loud hum out of my speakers long before I get all the way up. The hum increases the more the tubes are balanced (hum decreases when tubes are unbalanced). This happens in both channels.
My amp is a mostly stock build using 6GV5. The divergence from stock is in my OPTs. They are from Knight kit integrated amplifier that used a 5-20 type circuit.
We will need to know some of the DC voltage levels with no input shorted to ground and no feedback to start to help you. The amp should be DC stable, take the schematic and do a voltage map on one side.
Is the 6.3volt for the heaters center tapped? and connected to about 50V?
Did you populate the correct resistor positions for the 6GV5 ( 6JM6) not 6JN6?
B+=350V G2 Screen =150V Neg bias around-60V
Both plates on the input tube about 110 to 130V?
What does it do with the input tubes removed?
Since this design includes gNFB, it looks like Mr. Murphy wired you up for positive feedback, not negative. You might want to try reversing the plate connections to the primary of your OPT. If that doesn't fix it, more details please.
That isn't far off the mark. Luckily I am A) using cheapo goodwill speakers that will can handle a lot of abuse and B) encountered it while bringing up the bias so I could just back it off when it started.I would call it an 'earth sharttering OMG my speakers are going to die' noise rather than a hum.
./e
Thanks for the rapid input folks. I'll rewire and give it a shot as soon as I can...which isn't always soon between work and the lil' ones going to bed at 7pm. Yowling amps in the night don't make the missus real happy
Yep, that was it. Thanks again. I'm am soooo happy that this thing is finally going. I bought my board 51 weeks ago. It has taken me a long time to get this far. Next is to see how it sounds with speakers that are good for anything other than testing. Now I have some tidying up to do and to make a pretty box for it to live in. I've got a nice piece of chechen (aka black poisonwood) that I think will do nicely.
I've not seen that choice before. so I looked and it should be very nice with the grain. I have a plank of South American Rose wood that is lightly grained that I found for my amp and preamp set. amp will set on the preamp and the grain will flow between them.
chechen pic attached for example.
You will enjoy the amp and have a hard time working on it when you are too busy listening to it!
Hooked up to a set of Snell A/iii now. Sounds very good...more and more so with each passing minute. There is a bit of a hiccup though. When playing music with ridiculous amounts of low bass (e.g. Santigold - Fame) things get rough. I get distortion throughout the spectrum. When the bass hits the vocals warble. I am guessing that this is some sort of interaction with the speaker because when I bi-amp the speaker so the DCPP is getting the full signal but only handling the mid/tweets then everything is fine. While the DCPP does make a spectacular boom I am just fine with the bi-amp situation (400wpc of iron-fisted Ashly). I'd still like to understand what is going on here for sure though.
- Tubes / Valves
- Posted new P-P power amp design
