Post your Solid State pics here
thanks jacco
We can download this Motorola Fully Symmetrical amplifier here:
http://home.eunet.cz/rysanek/pdf/
Motorola AN1308-D: mot-amp2.pdf
There is also one other motorola amplifier Note: mot-amp.pdf
And one IRF HEXFET Amplifier application: irf-fet-amp.pdf
The Philips short note/tutorial on OpAmps may interest some
AN165: Integrated operational amplifier theory. philips-on-opamps.pdf
Motorola Fully Symmetrical 100 Watt, using 3 pairs of 2SC3281-2SAS1302
Re PCB!
OK size of Main board, what about size of 2 little PCB.
Do you have all dokumentation of this Amp.
I, ment PCB without silk skreen layouts for Main + little.
One word complete doc! for toner transfer technique!
Thanks!
Regards zeoN_Rider
dhengkoel,
It looks like they are the signal wires of both the channels. If yes, then u should not twist them as crosstalk between channels will increase due to capacitive coupling.
U have to twist signal/ground individually, and not signal L/signal R.
Gajanan Phadte
