Mooly said:Hi Anatoliy,
Is that a key to switch it on ? What is it anyway ?
Pyramid-V prototype. 2x80W nominal, Russian military tubes. MOSFET voltage regulators for filaments, screen grids, pre amp. This is a concert version, with grill top and TRS ins/outs. 0 dB input, outputs: 4, 8, 16 Ohm. Transformers custom made by EDCOR USA for 20 Hz - 20 kHz on full power.
Studio monitor version has a rack mount face plate; home stereo version has banana and RCA sockets.
The switch is for safety purposes.
Mooly said:A serious bit of kit then by the sound of it. Very nice job indeed.
Regards Karl
Thanks Karl!
It sounds really nice as well; now it works in my living room playing music through phased arrays made for concerts. I forgot to mention, it has a proprietary anti-clipping network with optical compressors. Ever clean sound.
Looks very nice and retro.
(though i rather spend my time keyhole peeping Veronica at Anatoliy's multi-culti forum, mind you)
hello!
nice to see a good place. 😀
my amp is very simple, and gives good results.
it works 24/24 everydays since 3 years now.
Hi edfed!
Nice work!
Can you tell something more about your amplifier?
Seeing the IC on input i guess that amplifier works on 2x15V, so it can give 18w per channel 🙂
Nice work!
no way.
supply is +/-17V serial regulation, up to +/-18V for IC, up to +/-26V from transformer.
Rload is 4ohms
then, p = (16/sqr(2))² / 4 = 32 Watts RMS
if i use it in full bridge configuration, it will output many more.
p = (32/sqr(2))² / 4 = 128 Watts RMS
with only few common components.
the secret is in the power supply.
current limit, perfect regulation, what is 100HZ? i don't know.
4 big condos.
10000µF 40V lsr
Rload is 4ohms
4 big condos.
10000µF 40V lsr
MF-A1
.my small power amplifier is the clone of MF A1.
.the capacitor bank.
regards:
gustOmO
regards:
gustOmO
laipanda,
wow, very well executed. I have to concur with lineup - beautiful.
where did you get your front plate from?
Edfed,
Can You post bigger pictures of amp, can not see the components values. I'm interested in this amp.
Thnx
Thnx
pirej:
i don't draw the power supply because it is too hard, and i have it in a harddrive somewhere.
power supply:
2 * 17 V
current limit 2 * 6 A
[message to owner of the board]
why isn't it possible to private message and edit posts?
power supply:
2 * 17 V
Motorola 100 w audio amp
..... my new amp from Motorola application note http://i36.tinypic.com/2u76jro.jpg 😀 alex mm
Re: Motorola 100 w audio amp
6 output transistors = 100W Nice!!!
Do you have schematic of this Amp, PCB?
Regards zeoN_Rider
alex mm said:..... my new amp from Motorola application note http://i36.tinypic.com/2u76jro.jpg 😀 alex mm
Regards zeoN_Rider
Thanks alex mm, here is linkxp@sezampro.yu
Regards zeoN_Rider
Regards zeoN_Rider
- Post your Solid State pics here
