Well, guess I learned a bit from my self caused XA 252 problems, which just helped with PoP accident. Converted to dual mono
and in process had amp on floor, top off and unplugged. Used "magic wand" to discharge PS and kitty jumped in amp, saw look on my face
and jumped out. oh well curious kitty! unfortunately, he stomped Q1 Q2 with heat sink straight down, doing same to small three legged T item just above.
I straightened things out on those pieces, made sure legs not touching, but no joy from that channel.
Removed Q1-Q2 assembly, led and small T item. Tested them in Chinese gizmo, all testing fine. (BTW, this time did removals with iron and solder wick,
leaving them looking brand new). Replaced parts anyway, and all fired up fine! I know, spinning head emoji!
Gave more confidence to reassemble XA 252 board project!
Thanks for your support as usual,
Russellc
Russellc
Cats.....what are you going to do? I had a main coon that would jump on top of row of albums and scratch across them. It
would anger me at time. That cat has been gone for over30 years. If I could have her back for one week, I would pile them
all up in driveway and burn them!
Russellc
Russellc
One thing I notice, post repair, both channels that I am fairly sure didnt happen before with this amp. On turn off, few seconds goes by and the leds on board shut off. Now, ( I'm pretty sure) they turn off, then back on and off a time or two. Probably nothing, about to put in system and see if its something I can hear popping at all. If not, I suppose this is no big deal?
Thanks,
Russellc
Thanks,
Russellc
Reminds me on the behavior of the P3's LEDs.One thing I notice, post repair, both channels that I am fairly sure didnt happen before with this amp. On turn off, few seconds goes by and the leds on board shut off. Now, ( I'm pretty sure) they turn off, then back on and off a time or two. Probably nothing, about to put in system and see if its something I can hear popping at all. If not, I suppose this is no big deal?
Thanks,
Russellc
But - it doesn't matter, great that you have sound! Enjoy!
- Plethora of Pinjatas / SET P amp(s)
