Pizzicato, a 200W low distortion CFA amplifier
Hi
I think, this PCB, it's not the best, approach, but means something, work in progress .
Joined 2011
Perhaps former member Tournesol is not-banned and actively participating in other internet discussion groups, under a different username. If you discover him elsewhere, you could inquire whether he continues to make progress towards completing the design and construction of a Pizzicato amplifier.
good luck to him, i always suspected him to be Esperado another banned member, although i have no proof, just a hunch....
A plan yes. A date to test may be looking too far ahead. This is one of those projects that is not guaranteed to work.I would recommend backing up a bit from the PCB. Some may wish to go straight to the PCB stage in order to advance. However, I place some importance on understanding the behavior of what has been formulated. In this case the input stage is slightly different and getting a grasp of how it works thermally is going to feed into future work.
With that in mind, I would initially bread board with discrete non-matched transistors which was my initial suggestion. The purpose of this would be to determine where the design concept breaks and how closely a match of transistors is required. The power devices do not need to be included as feedback can taken from the driver stages and a lower voltage version can built for concept test as well.
Of course you can opt for the PCB and see what gives. Since a lot of work is falling on your shoulders, you can direct others to give you what you need.
