Pioneer N-50 power blue led blinking,unit is not booting up
Once I was repairing a SMPS which dropped output voltage a while after power up. Some while after unplugging the voltage was OK again. The culprit was a temperature-dependent voltage reference (actually the basic TL431) - when the PSU got warmer, the voltage reference started dropping output voltage. After cooling down upon power off the voltage was OK again. Sometimes electrolytic capacitors produce the same issue.
I would probably start with measuring output voltage of the power sources and monitoring what they do after cold power up. If it turns out the cause, a specific PSU can always be fixed or replaced somehow.
