Pictures of your diy Pass amplifier
Naked XA252
and temperature inside is?
I presume you have top covers
if not, just ignore me :clown:
Sad story. The amplifiers have been in storage and now both seems to go into DC protection mode. Turning off after a few seconds. I seem to recall one had such a problem, and the theory was a bad JFET. Seems I have got myself some labour. But I have borrowed temperature probes. That is a start. More later……
These guys are right. That big metal bar is a bad idea. I would remove it immediately. Mount the toroids with the hardware that they give you when you buy one (bolt, top plate, flat washer, split washer, and nut). Then find some other way to mount that wiring distribution block.
I don't want to take merit of the build, it was a tech to do it for me but then another one, locally, had to fix some issues with the rectifiers cooling and the soft start.
Now, with the help of the community, I am taking measures to check the voltages across the mosfets to try and find out if the amp is correctly biased as it seems it can't really sound as it should, hopefully I can get down to at least find out if there is something to dial or if the 25W just can't make it with my speakers.
Grazie @ghitus questa è la prima volta che metto le mani in un oggetto del genere se non altro almeno per fare delle misure e spero anche per regolare il bias
Reactions: ghitus
