Look. There is a wire you can see on the floor beneath the caps on the right. There is room UNDER the caps. Probably they are there.
Very Nice work! The attention to detail is outstanding. Now I have go back into my project and due some tiding up.
Chad
Chad
Under the capacitors you find the two 600VA transformers.
You can see it on the picture.
The complete weight is 51,4 kg
The torobars are cooled because the high current (7A).
They are thermally coupled with the U-shaped Heatsink. You see it grey between coils and the Heatsink.
The black heatsinks over the coils are for the softrecovery rectifiers. They need good cooling.
It is only a effect on the foto because i used a teleobjective of a reflex camera.
The black toroids have a normal size of 150mm and the caps 77mm
Aleph2 !
It would be interesting if someone could break down the differences between all the different Pass models around here, so many different models it does become overwhelming...
Not using your F5 anymore ?
Patrick
Balanced F5 is my favorite, thank you very much Patrick !
I use it in open baffle for midrange(Supravox) and tweeter (Fostex).
Aleph2 use it for bass (2 x Eminence Alpha15).
The two amplifiers make me very happy🙂
Fantastic Finish. Where can I find those cabinets? I want to build my own with that kind of looks and a few extra details. can you point me in the right direction?
More details 🙂
Pictures by Buffalo22 - Photobucket
http://www.diyaudio.com/forums/pass-labs/172053-aleph2-project.html
is this fisher heatsinks?
- Pictures of your diy Pass amplifier
