Pictures of your amplifier's case
back view inside
Here's a pic of the pair. They aren't finished yet still some smoothing out left to do on the front panels and the amp case is still empty, it's too cold to work in my garage right now. These will be the first amp a pre that I've made so I want them to look good.
Bricolo: he,he...
This is finger contact ( on/off). I made it of transparent plastic with stainless steel center. Plastic is illuminated by red/blue ( protection on/off) LEDs behind. More on koy.hi-end.org ( unfortunatelly Czech version avaible so far, I am working, as time allows, on english one).
Nice these Bulgins. This one of mine made for me a friend. He works in aircraft factory and has everything he needs (turning machine, etc.)
It is made from roll of plexi-glass and in the center is milled a small hole for steel roundlet. The plexi roll bears on the switch of protection circuits and is enlighted by LEDs. If somebody is intrested I try to make a snap. Tomorow.I am not at home now. I am at work.
Allied Electronics sells 'em for about $18 a pop. Here's the catalog page pdf: Bulgin Switches
se
I already said they were expensive, farnell also stocks them but not the blue ones (yes they have them with a BLUE led, for all you blue led fetishists). From the top of my head i thought even a bit cheaper....
do you know other swiches (yes, I'm looking for a swich, not a pushbutton) that are cheaper?
In this style, maybe a little smaller.
A round swich, in metal, with led
Bricolo said:
the thing is, that I'm building a TDA7294 based gainclone
and this chip has a mute/stdby function 😀
...And you're thinking of using this switch for muting? Sounds good, even if expensive perhaps for this Bulgin option.
The LM3886 also has a muting function, as well as the LM3876. I have heard many claims that this muting circuit is bad for the rest of the circuit. But I don't see quite why yet. Can anybody risk an opinion?
Halojoy has also raised the question that he doesn't quite believe that an inverted gainclone will necessarily sound better than a non-inverted, and I think I am with him.
We seem to be rejecting certain opinions from objectivists that raise measurements as THE LAW to be worshipped, but we are creating new idols apparently, with no tangible proof they do exist indeed.
About the inverted vs non-inverted question I've read reports from DIYers that built both and it was really a matter of preference, not audio quality.
And I'm afraid this muting option (which can be practical if used) became a new idol.
And idols are not something I really like...
Carlos
