Photo Gallery
HV delay and Bluetooth, was the wish, of customer. I layout, a small PCB for this requirement . It work well, time adjusted to 40 seconds . Relay changed to SSR the blue one.
Nice work! I'd be interested in the delay schematic if you're prepared to post it. I just had to do something similar (Really soft HT start for DHT amp) but needed to use 2 relays because my customer didn't want a MOSFET in the HT.
Thanks, schematic attached . If SSR it's used , 270 ohm resistor must soldered in place of coil of mechanical relay.
Space is an interesting topic. I’ve chosen to eliminate the space a table/rack takes up. The inside pair are umbilical joined, the outer pair are mono blocks. There’s room for more 🙂
These chassis’s present around 550 square inches by 4 or 5 inches deep and I use it all. Lots of iron in my favored designs 🙂 Short signal path up top but the power supply is spread out some. I live away from the city so FM/ radio is no big deal. Amps are quiet.
Very interesting build. Looks good.
Headphone amp for 1626 output tube using Bob Danielak’s classic “Darling” circuit, switchable with the later “Clementine” variant by inserting 8532 or 6SL7 input tube. Lundahl LL2765 OPTs, vintage PIO coupling caps, and carbon comp grid leak resistors contribute to its involving musical sound. I modified Bob’s design by employing a separate cathode network in each channel, rather than a common one shared by both. It sports a dual chassis of African padauk finished with Danish oil and lacquer. One shielded umbilical carries the 6.3V and 12.6V AC heater supplies while the other carries the HT voltage and signal ground; both carry the chassis ground via the shields and a conductor. I designed a power supply with the type 80 rectifier into a double pi filter with 10h chokes and oil-filled motor run caps. It’s only begun breaking in but sounds excellent so far. I listened to Radiohead’s “House of Cards” 4 or 5 times last night.
nicely done!
and that Jetsons post was looking good too!
I finished an 801A A2 design the other day, I spent a lot of time and effort on it, very happy with the result. I posted pictures from the build in a dedicated thread, this is my favorite.
Here is the circuit.
superb workmanship on that chassis, you clearly took a lot of care and insisted on quality, all the way down to the special volume knob, immaculate surface finish and the wiring to the top cap, perfectly cut holes, countersunk screws, everything just done right. Puts mine to shame.
Thank you! I cannot claim the workmanship on the chassis itself, that is outsourced to Dave at Landfall Systems who does excellent work, highly recommended. I designed the chassis and layout in CAD software, picked out the powder coat and shipped it, Dave did all of the hard work with the machining and coating.
Some time last year, I began powder coating chassis at home, which inspired him to buy some equipment. Now he is much better at it than me! Which is a relief, as it is a one stop shop for a high quality chassis, which I think is worth the price.
Wow, this looks really, really professional !
Very good job, even my wife would allow me place it in our
living room (yes, I did show her this picture).
Another MA-1 is built. This one has safety interlocks AKA no B+ with C-...
Push pull trioded 6P36S for output (but since it's modular there are over 150 possibilities now) and my usual 6F12P/6N8S VA/PI/DR stage. SMPS for heaters and DC boost for bias supply. Also AB-4 for automatic bias. B+ 315V, 75mA idle. 2k2:6R loading.
Someone said they though the stacked toroids looked bad, so here a pair are hidden inside the chassis with the covers on top for once!
