EC8010 said:Gentlemen, if you are wondering why this thread has suddenly changed its name, it was a mistake on my part. Normal service will be resumed as soon as possible. My apologies.
I changed the name, but can't remember what the exact title was ... senility you know... it is also sticky again.
dave
What about the values?
Any detail on each component?
You're scheme doesn't show any detail (value) for each component.🙄
Any exotic part used? I can see a large Orange 😎 Drop from the pic.
my disign
this not mine exactly, but my partners.
500VA power input
2X25W output only
A class. sound good, but need not compressed drivers
http://www.artmaydan.org.ua/valve_amplifier.html
500VA power input
2X25W output only
Hmm those are both two really kickass amps guy's 😎
I think I'm getting a steel rash tho from moamps work...
Just feels GOOOD
Just feels GOOOD
nothing really it's what i have laying around😉 . its from my old amp that blew up. it's the only thing that works😀
i find it sound's better than a 5687 preamp i had..
Neato, just don't forget to oil or varnish that steel otherwise it'll rust up like nuthin'... (at least, it looks like plain steel).
Tim
Tim
no problem's yet ran it all saturday. just a small grounding problem i need to work out. i went to turn on the pre with the amp at the same time and got a little jolt nothing major but i dont
think the wife would like it😀
making some changes today
yes it does sound great for it's size.
Finished my phono stage !
Here's my latest effort. Just a 12AX7 RCA type phono preamp with passive RIAA. Ok, so there are probably better and neater ways of getting regulated HT, but glow tubes look so cool !
Went for the two box layout to minimise noise and hum. Sounds pretty good to my ears so far.
http://www.mthain.dsl.pipex.com/tube/images/phono.jpg
The one in the middle is but the one closer to the camera looks more like a decatron. SHAME ON YOU! It should be spinning at 60Hz! 😀
Tim
Tim
The taller tube is indeed an 0A3 but the other is a bit more unusual. It's a G120/1B or CV438 (see http://www.tubecollector.org/cv438.htm). The version I have is a bit taller but it's in a deep socket which was originally for a high voltage rectifier - I'm a bit short of B4 bases. Definitely one of the nicest looking glow tubes I've seen.
If you've just worked out that 0A3 and G120 = 130v and are wondering how the 12AX7's are working at that.. Well, I also have an 0A2 tucked behind the 0A3 giving 280v in total.
- Tubes / Valves
- Photo Gallery
