Next my experiment - just finished....SE E130L-Micron & 6Н8С & СГ4П with "monster" sound - about 10 Watt per channel. Cool tube! OT about 100 W- core 12 sq. cm, gray iron plate 0.3 mm.
https://picasaweb.google.com/109570777566485968551/Amplifiers#6008120183370077250
E130L and СГ4 in the dark: https://picasaweb.google.com/109570777566485968551/Amplifiers#6008481071039449874
I forgot to change the knob....
Wow....I had a look at your Picasa gallery.
Amazing loudspeakers.
I'm a fan of woodworking, more than electronik. I'll pick some good ideas from it if allowed.
Loudspekers made out of plywood layers e.g.
Ok ...no problem.Thanks for the info.
Thanks mhouston next project EL300PPDHT2009: extremely nice. You should be proud.
My Hi-Fi Headphone amp project
Hi, after a long time I finished my project Hi-Fi headphone amplifier. These are photos of the first production series for my friends and buddies. Perhaps you will like them.
PS: Excuse my bad English
More pictures here:
Gallery
more graphs here
Best regards
Marek
More pictures here:
Gallery
more graphs here
Best regards
Marek
I'm curious as to what voltage/RAA you will usenext project EL300PP
Nice I used the same power supply simulator change the value of the cap esr from 2 ohm to the spec sheet it changes the results some but not much. Regards
PSU for EL300PP
I used polies in my 300B also. I used Mundorf M-Tube caps. Not cheap but when you want something very special you must start with a very special PS.Integrated 300B amp I made many years ago. All polypropylene power supply.
I have Mundorfs too in power supply.
- Tubes / Valves
- Photo Gallery
