I like
Well I like it. If it hums like a a cockroach in your inner ear then do something about it. I like your big knob??!!?? AND I like the tubes. They are super cool
Nice considerations. Charming. Well, the space is great but here it doesn't matter. I've got this unique vintage power trans with such a tube placement, manufactured in 1953 for some kind of a specific device for the Sovier Army. Great core iron.
I like rockets since my next of keen was a pilot of the TU-95 aircraft "Bear".
About trying anything ... any try is a chance for the advance and progress. Thanks for wishing the bless.
Have a nice day!
up date wiring.😉My second amp 300B with interstage NC16 😛
Telefunken RS329g
Hi guys,
need help! found a bunch of these beautiful HUGE Telefunken RS329g transmitting triodes.
Anyone got a data sheet? These MUST be used in a big AMP.
thanks for any help!!! (the foto on the right is not right ;-))
Hi guys,
It is all hand-made.
Is that a headpohone amp. It looks really "Cute". I know that is an odd adjective for a tube amp but really I hope it sounds as sweet as it looks.
Yes it is a headphone amps and it can be a preamps too.Is that a headpohone amp. It looks really "Cute". I know that is an odd adjective for a tube amp but really I hope it sounds as sweet as it looks.
and you can rollling tube to what sounds you like.
tube you can use 12AU7 6DJ8 or 6922 and ECC82.
now I use 12AX7 and RCA6201
all different sounds.
SE 6S4S
My new SE amp with russian tubes 6S4S
Picasa ??? ?????? - Azazello - amplifiers
Just thought I would post an amp I made a while back:🙂
Fixed bias 8xEL34 or 8xKT66 or 8x6L6
Switching for Triode, Pentode, UL.
M. Gregg
M. Gregg
Hi
This is one of my amps:
Gm70
6sn7=>6h30=>300b=>gm70
Gm70
Hi
Gm70
Gm70
M. Gregg
What tubes did you use for the phase splitter and driver?
Hi
Gm70
Now that's a proper AMP! 😀
Amazing!
Say, how do you supply the filaments of 300B and GM70? I bet it runs very hot, but how hot? Does the top plate of the chassis touchable?
Hi guys,
I'm guessing you found the below, if not...
RS 329, Tube RS329; Röhre RS 329 (RS329)
This was an amp that I used to try different ideas! As it stands in the picture it had 12AY7 input tube, with silver cable and Jensen caps (Paper in oil). I can't remember the splitter topology. They were the small triodes. I tried 12AX7, ECC81, ECC82 in a few experiments.
I could never make my mind up if I liked Triode, Pentode or UL. After stripping it more times than I care to remember, I put switches on the back to select the different outputs. I remember trying all grids to anode in triode operation instead of just moving the UL connections. This gave a very "HIFI" sound. However I found that it depends on what you want to listen to. I like alot of different music, and have never heard an amp that seems to cover all requirements! Ongaku included! 🙂
M. Gregg
My new tube RIAA preamps.
Any chance of inside shots, they look brilliant!🙂
M. Gregg
Inside view.
- Tubes / Valves
- Photo Gallery
