Photo Gallery
Mal,
Yep that is exactly what those are. I would say to buy a batch of 10, because at first I had some arc-overs during prototyping. It was probably my own mistake though, because I didn't take as good care for their layout as I should have. There is a max heater to cathode rating that I didn't want to exceed, so I tied the heater to the cathode, in effect making it direct-heated. They're reliable in full wave bridge with heater tied to cathode now, and also make sure to insulate the individual socket contacts well with heat shrink. You see that I used four of these diodes - one each of the others are used in the series with the driver's dual-mono supply just for slow startup and dropping a little voltage. The amp sounds phenomenal, and I would definitely use these diodes again!
And one more tip - if you plan to pair this with high eff speakers >95db and are sensitive to any hum/noise, then I would recommend trying DC heating of the diodes.
Cheers mate ,thanks for the info :).
Tubelab SE 45
Pictures did no go through.
D.
My reference Amp, It drive the JBL 4344 very easily. I'm must used 16 caps 560uF/450V in power supply for bass enought strong at full Power output.
Specifications:
- Vacuum Tube Complement:
8 x 3D21WB, 2 x 12SL7 , 2 x 6BX7
- Output Power 90 Wrms (4 Ohms)
10 Hz – 50 kHz ± 3dB (at full power)
- Class of output operation: AB1
- Input Sensitivity / Impedance: 1V / 100K Ohms
- Dimensions W x D x H: 42 x 42 x 21 cm
- Weight per unit: 36 Kg
Hello All,
Any of you have built OTL tube amplifiers ?
Here are my 2 OTL mono blocks (built in 1993) - I hope that the picture will be displayed correctly below :
A+!
Specifications:
Good professional design. I like it.
Parallel 6AG7 SE
Hello all!
Here is my amp. Mixed schematic from several sources.
Output stage with Russian 6P9 (6AG7) two in parallel.
Screen stabs are STR 150/30.
Line stage – Russian 6N8S (6SN7).
Bias rectifier – Russian 6X6S (6H6).
Power rectifier – Russian 5Tz3S (5U4G).
Nice considerations. Charming. Well, the space is great but here it doesn't matter. I've got this unique vintage power trans with such a tube placement, manufactured in 1953 for some kind of a specific device for the Sovier Army. Great core iron.
I like rockets since my next of keen was a pilot of the TU-95 aircraft "Bear".
About trying anything ... any try is a chance for the advance and progress. Thanks for wishing the bless.
Have a nice day!
