Cheers mate ,thanks for the infoMal,
Yep that is exactly what those are. I would say to buy a batch of 10, because at first I had some arc-overs during prototyping. It was probably my own mistake though, because I didn't take as good care for their layout as I should have. There is a max heater to cathode rating that I didn't want to exceed, so I tied the heater to the cathode, in effect making it direct-heated. They're reliable in full wave bridge with heater tied to cathode now, and also make sure to insulate the individual socket contacts well with heat shrink. You see that I used four of these diodes - one each of the others are used in the series with the driver's dual-mono supply just for slow startup and dropping a little voltage. The amp sounds phenomenal, and I would definitely use these diodes again!
And one more tip - if you plan to pair this with high eff speakers >95db and are sensitive to any hum/noise, then I would recommend trying DC heating of the diodes.
Sonus Faber Grand Piano.........
...if you want to drive them very good,you need a "welding machine amp" for those.
In case you don't want biamping for your sistem you should try on your local guys to experiment on Maxonic speakers or similar or...a very good back loaded horn type enclosure (Fertin-fullrange speaker or FS speakers).
![nownow :nownow: :nownow:](https://files.diyaudio.com/forums/images/smilies/nownow.gif)
My reference Amp, It drive the JBL 4344 very easily. I'm must used 16 caps 560uF/450V in power supply for bass enought strong at full Power output.
Specifications:
- Vacuum Tube Complement:
8 x 3D21WB, 2 x 12SL7 , 2 x 6BX7
- Output Power 90 Wrms (4 Ohms)
10 Hz – 50 kHz ± 3dB (at full power)
- Class of output operation: AB1
- Input Sensitivity / Impedance: 1V / 100K Ohms
- Dimensions W x D x H: 42 x 42 x 21 cm
- Weight per unit: 36 Kg
Specifications:
I'm with this guy. Knockout amp. Makes my SETs look like toys.Air Power -- WOW -- very special workmanship.I presume that you designed the board. That alone is a lot of work.
Hello All,
Any of you have built OTL tube amplifiers ?
Here are my 2 OTL mono blocks (built in 1993) - I hope that the picture will be displayed correctly below :
A+!
A+!
Specifications:
Good professional design. I like it.
Parallel 6AG7 SE
Hello all!
Here is my amp. Mixed schematic from several sources.
Output stage with Russian 6P9 (6AG7) two in parallel.
Screen stabs are STR 150/30.
Line stage – Russian 6N8S (6SN7).
Bias rectifier – Russian 6X6S (6H6).
Power rectifier – Russian 5Tz3S (5U4G).
Hello all!
Nice considerations. Charming. Well, the space is great but here it doesn't matter. I've got this unique vintage power trans with such a tube placement, manufactured in 1953 for some kind of a specific device for the Sovier Army. Great core iron.
I like rockets since my next of keen was a pilot of the TU-95 aircraft "Bear".
About trying anything ... any try is a chance for the advance and progress. Thanks for wishing the bless.
Have a nice day!
Have a nice day!
Wow, rectifier tubes on top of power transformers. Saving space? Talking about space, by any chance do you like rockets?
This arrangement used to be more common than it is today. I guess it makes sense, in many ways.
- Tubes / Valves
- Photo Gallery
