the 2200 uf caps should be I guess no more than 12.5mm and they should be audio caps?
thanks
Yes. And 6.3V rated. These caps at this voltage rating almost always have 10mm diameter and 5mm pin pitch.
Hi Thimios.
The new zobel config is shown in the layout picture linked in post 1. C21,22 and R33,34.
Hi Thimios.
Thanks Shaan.
Nice work!🙂
I hope that I will have the oportunity to test this beast in the near future.😎
What is your sound card?
Sure no problemo!
It's on board Realtek "hd audio" chipset in a 2008 motherboard. Its output is horrible, but input is very good.
shaan,
Question on parts. What are you using for the 0.1R/5W resistor. I can only find Wire Wound resistors & the smallist one i could find, the body is 12.5mm long.
MFG P/N - RWHSE09TQ000R1FS
Rick
Rick
I was going to use these LVR05R1000FE12 Vishay / Dale | Mouser
but they are way to long, thanks for waking me up.
shaan,
Rick
These will fit perfectly and are easy to get. Wirewound vertical mount resistors.
Just a question, but has anyone have a BOM put together for Mouser or Digikey? I prefer not to recreate the wheel if possible.
Thanks.
Thanks.
GB Update:
rajesh - 2 PCBs (2 x pre-assembled modules) - PAID
vgeorge - 2 PCBs + 1 set of MOSFETs - PAID
gwrskien - 4 PCBs + 1 set of MOSFETs - PAID
bambadoo - 4 PCBs - PAID
medisinmannen - 2 PCBs + 1 set of MOSFETs - PAID
jacques antoine - 2 PCBs - PAID
Asuslover - 2 PCBs - PAID
vasillis - 4 PCBs - PAID
fencki - 2 PCBs - PAID
meanman1964 - 2 PCBs - PAID
muthumuthiah - 2 PCBs (stereo kit) - PAID
craydive - 2 PCBs + 1 set of MOSFETs - PAID
ckwong99 - 2 PCBs + 1 set of MOSFETs - PAID
jls001 - 2 PCBs (2 x pre-assembled modules) - PAID
mexakin - 2 PCBs - PM SENT
pieter t - 2 PCBs - PAID
reaper996 - 2 PCBs + 1 set of MOSFETs - PAID
883bkong - 2 PCBs - PAID
emynet - 2 PCBs + 1 set of MOSFETs - PAID
patriz - 2 PCBs - PAID
CitizenKane - 6 PCBs - PAID
Lutto - 4 PCBs - PAID
mj777 - 2 PCBs - PAID
yoaudio - 2 PCBs + 1 set of MOSFETs - PAID
yoaudio - 1 PCB + 4 MOSFETs - PAID
Rick G - 2 PCBs - PAID
Master Pain - 2 PCBs (stereo kit) - PAID
0.1R / 5W
... or the the MPC74 series from FUKUSHIMA FUTABA. The MPC74 (5 W) and the MPC78 (2 W) are declared as »Audio Grade« with low distortion, non magnetic and noiseless: Height 18 mm (± 1.0 mm) / Length 14 mm (± 1.0 mm) / Thickness 5 mm (± 0.5 mm) / RM 9 mm (± 1 mm) / R ± 10%
The high junction capacitance of MUR concerns me a little. This is not a linear characteristic so best to stick to the 4pF BAV.
BAV21 not available at most places...any equivalent you can suggestThe high junction capacitance of MUR concerns me a little. This is not a linear characteristic so best to stick to the 4pF BAV.
- Group Buys
- PeeCeeBee V4H GB
