Doing that now , but if I go too fast it just goes straight to negative ... none of the polarised components are in backwards ...?
Is it possible for P1 to be Fubar . I have tried adjusting for about an hour . I get to about 11.3 vdc and it swing to the negative ... is it telling me something ? it swings to - 24.32 vdc
Yes. Get rid of C7, if you use release boards from passdiy and ZVP3310. Then fire again 😎
Best,
nAr
changed P1 ... no difference . down to fuses lol . one led is way brighter than the other .
Can't find a schematic with voltages ....
thats enough for me today. If I charged myself my normal rate , I'd fire my **** !
Rich
Rich
Don't get too desperate. At least now PSU is turned the good way, and voltages are correct.
Unmount C7 as I said. Change leds and bipolars and see how it works. Can you get the voltages on the lowest resistors on schematic. At least it can help finding is biasing of each stage is correct or not. You'll also have to determine whether all the resistors are OK, or if one has now uncorrect value or seems damaged. last thing would be replacing jfets if one or more seem not to pass the intended current.
Best,
nAr
Best,
nAr
Thank you Nar .... C7 10pf out of both boards , but in the morning .
Yes, these are the official Pass boards . Just as well they were built to take my abuse !
Rich.
Rich.
Hi Nar ,
do I remove 3310 from the board also ?
I put a 500mA fuse in and fried R 29 ... why would that only happen on one board ?
Rich
Rich
Hi Nar ,
Rich
In that case I would also replace Q2, Q11 and R29
Can you do some measures and tell us which voltage you get in the usual places ? V+/ V-;
V on drain of Q6-Q9;
Voltage across R28 and R29.
Best,
nAr
Board 1
Q 6 , 31.2 mv
7 , 45.5 mv
8 , 32.3 mv
9 , 31.5 mv
R 28 , - 21.69
29 , - 21.69
Pad = -24.42
Board 2
Q 6 , 32.8 mv
7 , 31.6 mv
8 , 31.9 mv
9 , 32.9 mv
R 28 , -21.59
29, -21.49
Pad = - 24.33
Down to my last 250mA fuse . If I turn it off to remove ZTX 450 and ZVP 3310 . I'll blow it turning it back on ..... Why is this ? If I put a NTC before the fuse would it help ?
Rich
Q 6 , 31.2 mv
7 , 45.5 mv
8 , 32.3 mv
9 , 31.5 mv
R 28 , - 21.69
29 , - 21.69
Pad = -24.42
Board 2
Q 6 , 32.8 mv
7 , 31.6 mv
8 , 31.9 mv
9 , 32.9 mv
R 28 , -21.59
29, -21.49
Pad = - 24.33
Rich
Board 1 Board 2
Q 6 , 31.2 mv Q 6 , 32.8 mv
7 , 45.5 mv 7 , 31.6 mv
8 , 32.3 mv 8 , 31.9 mv
9 , 31.5 mv 9 , 32.9 mv
R 28 , - 21.69 R 28 , -21.59
29 , - 21.69 29, -21.49
Pad = -24.42 pad = -24.33
Rich
Across R28 and also R29 you should have 1 volt or so. I dunno 1st stage Q6_Q9 seems fine, slightly low but maybe in relation with IDSS of the particular devices.
It seems current flows without been controlled. Could be the CCS (bipolars-leds) / jfets / mosfet of the 2nd stage all blown. I'm afraid you'll have to change all leds, bipolars jfets and mosfets of the 2nd stage before firing up again.
Best,
nAr
Why would Q7 on board 1 be so high ... ?
when you say all bipolars .... you mean all polarised capacitors including my beloved M-lytics ?
I'll email Wayne for J fets .
I took these readings with brand new LED , do I still need to replace them ?
R
R
jfet IDSS matching / tolerance
No, bipolars are transistors ...
R
If they are lit normally, no; make sure they don't run like hell 🙂
Best,
nAr
Hi Nar,
fets are on the way .... Wayne will send me a schematic with some voltages
on it .
ZVT 3310 = replace , ZTX 450 replace , LED = replace . From the voltages it appears the regs are ok .
Should I put C7 back ?
Rich
on it .
Rich
Hi Nar,
on it .
Rich
Good. No, if you use ZVP3310 and Wayne's board, C7 is to omit, causes oscilations problems in some cases.
nAr
...if you use ZVP3310 and Wayne's board, C7 is to omit, causes oscilations problems in some cases.
I have Wayne's boards and ZVP3310. Would it be your suggestion to begin with C7 and remove if there are problems, or to omit from the beginning?
Wayne stated earlier on the thread to try first without, and add it only if you experienced stability problems ( offset drift uncontrollable, oscilations, etc.)
Best,
nAr
Very good. If I read about that earlier in the thread, it did not stick in my mind. Thanks for the clarification! 😀 🙂
A red one.
It is being used as a voltage reference, not unlike a zener diode, and the different colors have different forward biases. Red ones usually drop around 1.7v
Thank you ,
thats what I ordered 🙂
I will get this working , look who I have helping me , You, Nar , and Wayne.
You guys are the best ..... rookie luvs ya !
Rich
Rich
- Pearl Two
