Pearl phono PCBs Group Buy
This is picture from a friends boards that are ready and working perfect.
He also made a few measurements of the RIAA accuracy and the 2 channels are perfectly matched.
Resistors where 0,1% and capacitors the MKP Panasonic that where matched.
Hi Everybody,
Suppose I have interested in it, how to make payment ? Will any other payment option to choose ? ( I need a PCB and all transistors only)
Not sure Pearl phono can be drive by battery directly ? Will it need a various modification ? Such change will bring any advantages on music play ?
CK
Pearl on batterys
Hi CK
If you seach for pearl and battery you will find a thread where Wayne (who designed pearl, Ono......) describes what changes should be made to power the pearl of batterys. I Think you still want the FET regulator on the board, but the CRCRC filter could be jumpered to a CCC filter, as I think it would be stupid to use a ripplefilter in batterys. Batterys should make less noise......but still makes noise, and should have some capacitors over the supply.
But again, check the thread for the "more qualified" answers ;-)
Cheers !
Hans
promitheus said:
I am glad you are satisfied with the parts.
I am trying to start this project but I have so little time.:bawling:
anyway I am making small progress.
Does anbody have ideas on how to make a nice enclosure.
Would be helpfull to get a few ideas.
I used a cabinet from a local company that specializes in Amateur Radio kits. They sell a small cabinet that can accomodate both boards if you turn one upside down and mount it to the top. At $60, its not bad. Model is the EC2.
Here's the URL: http://www.elecraft.com/images/EC2.jpg
They also make a smaller cabinet now (the EC1) that I'll end up putting my power supply into. Right now its in an old PC power supply cabinet and is pretty unsightly.
David
Unfortunatelly I did not get my parts yet. I guess it takes a while to reach Canada...
Anyway,
I have a friend that is working in a company that makes enclosure and I am currently designing a chassis for this Pearl. It will be two separates chassis. The dimensions will be 16'' W, 12'' D, 3.5'' H. I know these dimensions are a bit too much but I want to build an X2 later and it is cheaper to make many chassis at the same time. It will be all painted black steel and the faceplate will be 3/16'' aluminium. If you are interested by this chassis, please let me know and I could tell you the cost (when available).
Its my fault its taking so long.
I should have sent it with airmail but they didnt tell me at the post office it takes so long.
It would have cost a lot more for airmail because the package is heavy.
I hope you aren´t mad.
Well at least you have something to wait for.
Well thanks for the offer but that would be a little big for my space here.
