PC becomes very slow to respond
In the post above I meant to say 'is it a full retail version and NOT an upgrade disc'. If it is an upgrade disc then you still can do a clean install but the procedure is slightly different, whih is what I did with Vista.
High CPU peaks are normal while browsing (especially when first loading a page), but the duration of the peak shouldn't be long.
Some (MOST?) anti-virus programs have "web protection" or "site filter" or some such. That always troubles the speed. It would be better (and considerably faster) to shut that feature off and use adblockplus.org instead.
A fast-n-dirty way to conquer hard drive related slowdowns while browsing, is to set the browser's cache to 12mb (12mb~15mb for firefox or 33mb~64mb for chrome), resulting in a considerably smaller mess.
You could also consider using Msconfig (already part of widows) to inspect the non-microsoft services and to inspect the startup items. Theoretically, the optimal number of both of those things is zero, and any exception needs to have a good excuse for it.
And you should see 'Action Centre' as a white flag. If its red then click it and see what the problems are.
Uninstalled the programmes that were added 2 days ago to help see what bugs might be in there. I also uninstalled 3 others and now there is a massive improvement in Memory it's down to 0.8GB with only Task Manager loaded and rises to ~1GB with TM and firefox loaded.
Handles are still high @ ~20000
Start up is much faster. Moving in the right direction.
Desktop with the egg timer appears in 70seconds, but can't use it, until almost 2minutes.
But that is about half the time from last week/month.
Browser is open in 2mins 10seconds.
Will still go back and review all the other tips.
I'll get my new motherboard and memory running first and then try a clean install on this one.
Thanks.
I still have my old HDD from my old XP PC.
Can I just plug that into the new motherboard and let it boot up?
Or does the new motherboard require a proper install?
I ask because that XP was originally an oem version and I don't have any discs.
All it's updates prior to 2014 are also on that HDD.
There was an option with WIN7, to install that and with some jiggery pokery get it to change to XP.
Does that still work, now that MS has moved on to WIN8 & 10?
That is an improvement.
If you do a clean install then don't rush into it. Set your stall out and gather any information you may need first. For example, decide on how you want any partitions to be arranged, and what size you might like. You might want several. Everything is your choice with a clean install, and yours to set up just as you want. Making a quick note of things such as driver versions for the graphics and sound cards is worthwhile. You can check these from your working install via 'Device Manager' and note them down. Then if there is a problem down the line you know what worked before.
We can talk you through what to do should you decide to go ahead. Its good fun setting a PC up from scratch and you learn a lot.
I don't think that would work for a couple of reasons. The HDD will have all the operating system PLUS all the other stuff to make it work such as drivers and so on, all configured for the old hardware. The other problem is that Microsoft would flag the system as invalid because the OEM license is tied to the original hardware electronically. You can get away with replacing an HDD or CDROM drive and so on, but a new mother board is essentially a new PC.
What will happen is you'll be asked to re-activate windows xp. That's MS. Even with W7, changing a video card will void your activation. You'll need to enter the code to re-activate it. If you don't have it, than that's it, you're locked out.
I don't switch HD with Windows loaded. I simply do a clean install. Takes a bit of time to load all the proper drivers but if done correctly, the PC won't be slow.
To remove softwares, I use Revo Uninstaller. Better than Windows. It'll even clean up all the junk files in the registry.
I have two paid licenses , but use a copy of W7-32/64 that is pre-activated.
To have the OS poop out for a simple hardware change would make it
useless for testing/repair and quite frustrating.
I would not own something so "bombed out".
OS
Windows will work "fine" without activation. For a while, like a week...
For changing a motherboard, what I've done several times is while it's still in the old system, start the installer off the CD/DVD. Have it do a "refresh" install, let it copy the files to the drive, and reboot. While it's down for the reboot, swap the motherboard out from under it.
That works fine in xp and 7. It does not work for 8.1, and "refresh" now wipes your installed programs.
IME the average person has no idea such resources exist. Some have no desire regardless, and some believe it sounds so good it must be illegal. I'd be surprised if the stats showed majority usage.
There's nothing special about it, except that it is designed to be user friendly for dummies...
Windows came with Internet Options, browser also came with security/privacy/connection setting options... When they are utilised, it's sufficient, and usually better than using add-on but with other things setup unsuitably. But of course this is less user-friendly...
Only by using standard feature (focus on COOKIES), may be with additional use of HOSTS file, advertisements will not show up in your browser.
Hmmm. The web is full of 'how to speed up my PC' tips many of which are misinformed or cause other issues to appear. A well sorted installation should fly along without needing to resort to all this.
(I think your install of W7 has seen so much tinkering and installing/uninstalling of stuff that you are really past the point of no return for sorting it. Sometime a reinstall is the only answer)
