Pavel Dudek's (Upupa Epops) LM4780 amp
As promised, a little fan on the heatsink of the amp, just for in case that.
It's a 12VDC fan, but i runs it on 6VDC so you do not hear any noise.
Ok. Third Amp finished with same results: relays close but no sound->input problem.
What do I do wrong?
1. Is a regular cd player output is ok as input?
2. + is connected in the first pin second row. - is connected to the first pin first row (groud).
3. A jumper is inserted to shortcut the - and ground.
4. Output is connected to the wago connectors related to the same input (jp5 pins 1,2).
Any help?
Another thing: The other channel's opamp is getting very hot and there is a white noise on the outside, but if I thouch its input it doesn't affect anything (not like the right/lower) input.
-> I replaced its opamp and it's like the other input now.
