P-A,
Thanks a lot for all the time and effort you have put in, I recieved my boards and inductors.
Pavel,
Thank you very much for your generosity for sharing your design.
Thanks again, both of you, much appreciated.
Dinesh
Pavel,
Dinesh
Assembly Manual Please
Could someone write a manual like this one, to help build it?
http://shine7.com/audio/pa150.htm
Have you read the existing one? If you want a stereo amp you only have to add 2 x 18-24 VAC, speakers and input. That's it.
YES! BEAUTIFUL BOARDS
YES! BEAUTIFUL BOARDS THANK YOU
peranders said:Guys, anyone that NOT has got their boards? Everyone happy in that department?
Yes I have read it
You assume I know how, Please, could someone post a visual
manual with step by step instructions and a wire connection
diagram for boards and power supply, and suggestions for
power supply.
Also how do the heatsinks get fresh air mounted in the middle
of the board? ......sorry I am so stupid..
Thank You
peranders said:Have you read the existing one? If you want a stereo amp you only have to add 2 x 18-24 VAC, speakers and input. That's it.
power supply.
Thank You
The manual can be found at http://sjostromaudio.com/joomla/index.php?option=com_content&task=view&id=73&Itemid=29
and should answer most of your questions. Good luck!
Bob G.
Bob G.
My dear friend, I mean, that instruction manual is written clearly enough, but you can things, which you should have learn at school.... 😎
Guys, english isn't my native language, so maybe something in instruction manual isn't told quite exactly. Please tell me what isn't clear and I will try explain it in other words....
Did you look at the link?
Please compare the manuals. adding the extra information helps.
Upupa Epops said:My dear friend, I mean, that instruction manual is written clearly enough, but you can things, which you should have learn at school.... 😎
Every parts, which are critical, are in my manual charactered. If not, so you can to use random access with this value. Correct kit for all world must be designed by this way. If you hesitate by some device, ask me and will tell you some closer specification....
Re: Yes I have read it
Being a newbie, or simply lacking specific knowledge, doesn't mean that you're stupid. Other forums I participate on generally end up starting a "construction thread" of said item, in this case the PA03 amp. That would be helpful to me as well for this amp, if for no other reason than info on sourcing certain components here in the USA.
power supply.
Thank You
I'm quite sure there will be good hints about the building the amp and sourcing parts. I would very much have good opinions so I can change the manual and/or the web page.
I'm sure Pavel knows the answer here but I think this isn't any major problem if you use the high heatsink and play "music". For really heavy duty this is a drawback, I'm sure.ppcblaster said:Also how do the heatsinks get fresh air mounted in the middle of the board?
I am having DSL and Telephone problems
I had to change Isp's and my internet and phone fail
intermediately.
Thank you for all the support.
intermediately.
Yes and nowim said:For IC1 (CD4020) i have a HEF 4020 from Philips. Is that the same component??
- Group Buys
- Pavel Dudek's super Gainclone group buy
