Ron, interesting comparison with Snell Type E. Btw, I ran into your Cherry Pi build on PETT forum and I should say a very nice build, inspiring too. Must have been a lot of work to accomplish something like that.
Oon, good luck with your diy endeavours!
That's a different Ron E. I haven't posted at PETT in a coon's age 😉 The 'other Ron E' is a much better woodworker than I am..but apparently we each share a similar lack of imagination in our usernames 😉
I think the peak could tuned lower and there should be less output at the bass...
In general WRT to PRs, should actually, dropping it at least an octave due to how they sound higher up, which in turn will likely require at least a 12" PR to get enough weight on it.
At a glance using Hornresp, it will only handle ~5W/100 dB/m to 30 Hz and making the cab > ~15 L gains nothing useful since like noted earlier it's only compliance controlled with this much series resistance.
GM
