I know they're nothing special, but I've always thought they were good value and they do have silver plated contacts
I have had Lorlin rotary switches in use for over twenty years. Only failed when there was mechanical damage. They are used to switch 70 volt loudspeaker lines. The silver plating is very thin and I suspect the internal lubrication is not up to the job for low level signals.
Hi Ed,
That is probably true. I've had them in use for signals, relay switching, speaker switching. The relay coils had diodes across them. In my experience, they are basically unhappy doing anything I've tried with them. I did like that you could select the number of positions yourself. Fantastic idea. Too bad the switches just don't stand up.
One thing about my use that might differ from yours is that they are used quite often. What I really did not like about them is the mushy detent as you change positions.
-Chris
-Chris
Passive Preamp Overview-II
This overview provides additional advices concerning the used switch/potentiometer parts.
other Keywords for "Passive Preamplifier" to find out more of such devices::
Passive Controller
Passive Audio Controller
Passive Stereo Controller
Passive Line Level Control
Passive Monitor Controller
Passive Stereo Control + Source Select
Passive Audio Volume + Input Control
Passive Line Level + AUX Controller
Passive Stereo Attenuator+ Input Select
Passive Selector+Volume Control
Passive Source Selector+Line Level Control
Passive Volume/Input Controller
Passive Line Stereo Controller
I. Rotary switches in use both for input select and attenuation that are available with the highest possible quality
Serious Stereo passive attenuator without model naming
Serious Stereo Ultimate Stereo Passive Attenuator for uncompromising Audiophiles
in use: Soruce Selector/Attenuator Shallco open frame rotary switch ("Our new attenuator is a knockout!")
Marchand Electronics Inc. Model PR141
Passive preamp / Stepped Attenuator w. 46 position control
audio stepped attenuator, precision audio volume control, remote control volume attenuator
input selector and stepped attenuator of the highest quality (various brands like goldpoint and ELMA 04)
Goldpoint™ SA4 and SA4M Passive Preamps
Goldpoint SA4 Level Control / Passive Preamp
http://www.goldpt.com/sa2x.html
http://www.goldpt.com/sa2.html
Goldpoint™ Level Control SA-2X Balanced XLR Passive Preamplifier
http://www.canuckaudiomart.com/deta...anced-xlr-passive-preamplifier/images/925295/
in use: source selector and attenuator: ELMA 04
https://www.elma.com/en/products/ro...tching-products/product-pages/type-04-detail/
http://www.shallco.com/IndustrialSwitchProducts/AdditionalSwitchProducts.aspx
Yamamoto Sound Craft "AT-03-3A"/"AT-03-1A" High performance Passive Attenuator
http://userweb.117.ne.jp/y-s/AT-03-1A,3A-E.html
http://userweb.117.ne.jp/y-s/Meikisyou2011-E.html
http://www.6moons.com/audioreviews/yamamoto10/passive.html
in use: source selector/attenuator: Seiden open frame rotary switch
http://solidgreen.co.jp/products/pdf/SEIDEN.pdf
http://www.partsconnexion.com/SEIDEN-74751.html
Phasemation (KYODO DENSHI) Hybrid Passive Attenuator CM-3/CM-1000
http://www.phasemation.com/product/cm-3.html
http://www.hifido.co.jp/KW/G/P0/A10/E/0-10/S0/C16-06189-00013-00/
Music First Audio "BABY REFERENCE" / "Classic 2" PRE-AMPLIFIER
https://mfaudio.co.uk/preamplifiers/
https://www.stereophile.com/content/music-first-audio-baby-reference-passive-preamplifier
in use: source selector/attenuator ELMA 04
Erzetich Immotus (SI-5290 Šempeter pri Gorici)
http://www.erzetich-audio.com/knowledgebase-09-preamplifiers
AudioLive "Passive Control Unit" (S-14233 Skogås Sweden)
http://home.swipnet.se/audiolive/pas.html
http://home.swipnet.se/audiolive/vol.html
Bespoke Audio
http://www.thebespokeaudiocompany.com/our-product
Amtrans Audio Passive Controller APCG-01S
http://www.amtrans.co.jp/products/passive_controller/index_e.shtml
https://www.dhtrob.com/impressies/amtrans_sats.php
in use: source selector/attenuator: own parts
Softone Inc. "Model5" (Selector & Attenuator)
http://softone.a.la9.jp/english/Model5/m5-1.htm
47 Labs / 47 Treasure Model "0447"/"0547" Passive Selector/Volume Control
http://www.47labs.co.jp/shop/html/images/0447_0547_CatalogJpn.pdf
https://www.pinterest.de/pin/449515606530408148/
in use: source selector/attenuator: unknown
Glasshouse Passive Pre-amplifier No.1 Kit
https://www.hificollective.co.uk/kits/glasshouse/passive-pre-amp1.html
https://www.rdhworld.co.uk/cu_arch/viewtopic.php?f=10&t=25864&start=15
in use: wide range of rotary switch offer for stepped attenuator from Glasshouse
https://www.hificollective.co.uk/components/stepped_attenuators.html
Audio Consulting Silver Rock TVC
http://www.audio-consulting.ch/?Products:Preamplifier:Silver_Rock_TVC
in use: source selector/Attenuator: ELMA 04
The Django preamp
https://www.tnt-audio.com/ampli/django_e.html
http://shop.diyhifisupply.com/product-category/kits-assembled/django-passive-preamp/
http://press.diyhifisupply.com/category/hifi-kits/django-passive-preamp/
in use: source selector/Attenuator: SEIDEN rotary switch
http://www.soniccraft.com/index.php/rotary-switch-seiden-c-338_342_375
II. Rotary switches in use only for attenuation (volume control) that are available with the highest possible quality
Khozmo Passive-Preamplifier - Dual Mono Selector
http://www.khozmo.com/dual_mono_selector.html
in use: LORLIN source selector/Khozmo stepped attenuator
https://www.lorlin.co.uk/catalogue/ck/
http://www.khozmo.com/index.html
Hattor Audio - ULTIMATE PASSIVE PREAMPLIFIER
http://www.hattor.com/index2.html#ultimate
in use: relais controlled input selection/Khozmo stepped attenuator
CANARY AUDIO CA-200
http://canaryaudio.com/200.html
http://www.audiocircle.com/index.php?topic=100359.0
http://www.canuckaudiomart.com/details/649312232-canary-audio-ca200-passive-preamp/images/1372824/
in use: source selector: ELMA 04 and attenuator: Alps RK27
NVA Model "P90sa" (Stepped Attenuator) Preamplifier
https://www.nvahifi.co.uk/p90sa-preamplifier
in use: source selector: not mentioned manufacturer. Attenuator: Elma 04/Shinkoh Tantalum resistors
https://www.don-audio.com/Elma-A47-Jumbo-High-End-Rotary-switch-1-Channel_1
Luminous Audio Technology Axiom II
https://luminousaudio.com/collections/axiom-ii-passive-preamp/products/axiom-ii-passive-preamp
https://positive-feedback.com/reviews/hardware-reviews/luminous-audio-technology-axiom/
http://www.hifizine.com/2012/09/luminous-audio-technology-axiom-ii/
in use: source selector toggle switch similar to
http://www.nkkswitches.com/pdf/d2.pdf
and Khozmo stepped attenuator
AudioZone Pre-T1
https://www.theaudiozone.ca/products/pre-amp/
http://www.6moons.com/audioreviews/audiozone4/pretone.html
in use: source selector: toggle switches, Attenuator ELMA 04
OSBORNE "The AM Balanced Transformer Line Stage Preamplifier"
http://www.osbornloudspeakers.com.au/AM/Passivepre.html
in use: source selector: cheap Alps SRRM262400 and attenuator: unknown (maybe Electroswitch open frame)
Thel Passive Preamp
http://www.thel-audioworld.de/bauteile/regler/Stschalt.htm#RSL
in use: source selector unknown, Attenuator TKD
http://www.altronics.com.au/p/s3015-12-position-90-deg-pcb-mount-rotary-switch/
http://www.thel-audioworld.de/bauteile/regler/Potis.htm#cp
http://www.tkd-corp.com/products/att/pdf/type-P2500s-e.pdf
Rothwell Indus SE Passive Pre-Amp
http://www.rothwellaudioproducts.co.uk/html/indus_se.html
and post #135 under
http://www.hifisentralen.no/forumet/hi-fi-generelt/22252-innmat-hva-du-vil-7.html
in use: Rotary switch for Input Selector (Taiwan Alpha) and stepped attenuator (Electro-Switch/Stackpole)
https://www.rapidonline.com/taiwan-...fore-break-rotary-switch-2-pole-6-way-79-0105
http://www.electro-nc.com/rotaryus/c2_3.pdf
http://www.electro-nc.com/rotaryus/c4.pdf
http://www.electro-nc.com/rotaryus/c7.pdf
http://www.electro-nc.com/rotaryus/m5.pdf (Mil)
SAC Thailand Model "MINUTE"
http://www.sacthailand.com/Amp_PrePassive.html
http://www.sacthailand.com/Amp_PrePassive2.html
https://www.stereo.net.au/forums/to...-sac-thailand-transformer-volume-control-tvc/
in use: source selector/attenuator Myjama/Seiden
http://www.miyama.co.jp/toggle.htm
III. Unknown Parts or Parts in use with poor or average or standart quality and short lifetime
Reel Audio PRM1
https://www.reelaudio.co.uk/PRM1.shtml
in use: source selector/attenuator Alps PCB rotary switch/RK27
BYKOZ Audio various Passive Line Stereo Controller
https://www.sahibinden.com/listing/...ed-attenuator-volume-control-522272516/detail
https://www.sahibinden.com/ilan/iki...ped-attenuator-volume-control-522272516/detay
https://www.sahibinden.com/ilan/iki...asiz-amfinizi-kumandali-yapin-522291759/detay
https://www.sahibinden.com/ilan/iki...f-pre-alps-stepped-attenuator-522270126/detay
http://www.bykoz.com/galeri.htm
HG Design Passive Preamp
http://hgdesignhomeaudio.blogspot.de/2013/07/fisher-x100-modified-clone.html
https://www.sahibinden.com/ilan/iki...mleri-kumandali-pasif-premafi-521556745/detay
in use: source selector/attenuator: unknown/Alps RK27
CANARY AUDIO P100
http://www.canaryaudio.com/P100.html
in use: source selector: LORLIN and attenuator: Alps RK27
Lab 12 True Passive Attenuator / Input Selector
http://www.lab12.gr/true
http://www.lab12.gr/sites/default/files/downloads/true-om.pdf
in use: source selector: not mentioned manufacturer. Attenuator: Alps RK271
https://docs-emea.rs-online.com/webdocs/124c/0900766b8124c575.pdf
http://www.alps.com/prod/info/E/PDF/Potentiometer/MetalShaft/RK271/RK271.PDF
Townshend Model "Allegri+"
http://www.townshendaudio.com/allegri/
http://www.tnt-audio.com/ampli/townshend_allegri_e.html
http://hifipig.com/townshend-allegri-passive-preamplifier/
Rotary switch for Input Selector (Taiwan Alpha) and ConneX stepped attenuator
http://www.partsconnexion.com/controls_rotary_connex.html
Malega Audio™ PS1™ and PS2™ Passive Stepped Attenuator
http://malegaaudio.com/product/audiophile-passive-pre-amplifier-ps1-stepped-attenuator/
http://malegaaudio.com/product/audiophile-passive-pre-amplifier-ps2-high-quality-preamp/
in use: Stepped Attenuator - cheap and not mentioned manufacturer
http://malegaaudio.com/wp-content/uploads/2016/05/DACT-type-Stepped-Attenuator.jpg
TISBURY AUDIO Mini Passive Preamplifier II
http://www.tisburyaudio.co.uk/mini-passive-preamplifier
http://www.hifizine.com/2016/04/tisbury-audio-mini-passive-preamplifier-ii/
in use: LORLIN source rotary switch/unknown stepped attenuator
(essentially a potentiometer that uses a track of resistors instead of carbon film)
icon Audio - Passive and Passive R Pre Amp
http://www.iconaudio.com/main-products/passive-and-passive-r-pre-amp/
SCHIIT AUDIO Model "SYS" (VOLUME CONTROL AND 2-INPUT SWITCH)
http://www.schiit.com/products/sys
in use: source selector ALPS SPUJ/SPUN Series, Attenuator ALPS RK097 series
http://www.alps.com/prod/info/E/HTML/Switch/Push/SPUJ/SPUJ_list.html
http://www.alps.com/prod/info/E/HTML/Switch/Push/SPUN/SPUN_list.html
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK097/RK097_list.html
HIFI EXQUIS MeiXing MingDa MC-9 SE Passive preamp
https://hifi-exquis.com/transistor-...mer-balance-preamp-7-times-amplification.html
in use: source selector/Attenuator: unknown - no pictures on the web
Hot Audio Solid Maple Audiophile Passive Preamp
https://hotaudio.com/buy-products/passive-preamplifiers/
https://hotaudio.com/20160824_131105/
Rockappella Passive Pre-Amp Mk2
http://reallygoodstuffs.com/Passive Pre Amp.htm
Douk-Audio RC Selector Passive Pre-Amplifier 3-IN-2-OUT
https://www.aliexpress.com/item/201...-OUT-Audio-Preamp-Adjustable/32741196008.html
in use: source selector: OMRON relais G5V-2 and Attenuator: Alps RK163
http://omronfs.omron.com/en_US/ecb/products/pdf/en-g5v_2.pdf
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK16/RK16_list.html
DALAUDIO PAS3/PV1
https://dalaudio.com/dalaudio-studio-pas3-passive-audio-selector-3-in-1-out-2ch/
https://dalaudio.com/dalaudio-studio-pv-1-passive-volume-control-1-in-1-out-2ch/
Little Baer MC2
https://www.ebay.de/itm/Nobsound-Mi...759726?hash=item3d494c912e:g:1rgAAOSwc6JacnZk
http://www.avx.hu/forum/index.php?/topic/108284-little-bear-mc2/
https://fr.aliexpress.com/store/pro...mp-XLR-RCA-Contr-leur/401371_32841578955.html
DODOCUS Design U-BOX 4CL (RC)
http://www.dodocus.de/UBox4C-L.html
in use: source selector: Relais-controlled, Attenuator ALPS RK271
http://www.hifituning24.de/passive_bauelemente/potentiometer/alps_poti_rk27112mc/index.php
FT Audio LW1 Little Wonder Passive Preamp
http://www.soundstage.com/revequip/ftaudio_lw1.htm
http://audioasylumtrader.com/ca/lis...-LW-1/amazing-passive-pre-amp-for-sale/174965
http://www.audioreview.com/product/amplification/preamplifiers/ftaudio/lw1.html
https://web.archive.org/web/20060115142304/http://www.ftaudio.com:80/products.htm
http://www.audio-ideas.com/reviews/preamps/ft-audio.html
Wright Audio PCC-1 Passive Control Center
http://www.wrightaudio.us/PCC.htm
https://www.gearslutz.com/board/low-end-theory/951548-palmer-monicon-anyone.html
Palmer Monicon PMC1 Monitor Controller
http://www.palmer-germany.com/pro/d...er-wei_szlig-limitierte-Auflage-PMONICONW.htm
http://www.palmer-germany.com/pro/de/MONICON-Passiver-Monitor-Controller-PMONICON.htm
https://www.testberichte.de/p/palmer-audio-tools-tests/monicon-pmc1-testbericht.html
https://www.thomann.de/de/palmer_monicon.htm
in use: no source selector - Attenuator: Alps RK097
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK097/RK0971221Z05.html
https://uk.rs-online.com/web/p/potentiometers/7293568/
Mackie Big Knob Pas*sive
http://mackie.com/products/new-big-knob-series
http://mackie.com/sites/default/fil...ANUALS/Owners_Manuals/Big_Knob_Passive_OM.pdf
https://www.thomann.de/de/mackie_bi...MI65z-vYOy2QIVHowZCh1ZEwWhEAQYAyABEgKYOvD_BwE
Swissonic M-Control
https://www.thomann.de/de/swissonic...MI65z-vYOy2QIVHowZCh1ZEwWhEAQYBCABEgInTvD_BwE
in use: no source selector - Attenuator: unknown - no pictures on the web
Monacor ILA-100RCA (Passive Stereo Level Control)
https://www.monacor.de/produkte/bes...-und-zubehoer/lautstaerkeregelung/ila-100rca/
https://www.monacor.de/produkte/bes...ubehoer/lautstaerkeregelung/ila-100rca/?r=pdf
OMNITRONIC VC-1
http://www.steinigke.de/de/mpn10355795-omnitronic-vc-1-lautstaerkeregler-passiv.html
Mammoth Cave Audio - wide range of passive monitor controllers e. g. "Ground Control DeLuxe"/"Passive Stepped Attenuator Plus"
http://mammothcaveaudio.com/wp-content/uploads/2014/07/GCdeluxecosole-1.jpg
http://garynobleshow.blogspot.de/2015/06/ground-control-deluxe-mkii-and-wooly.html
http://mammothcaveaudio.com/products/
ESI AUDIO MOCO
http://www.esi-audio.com/products/moco/
https://www.bboytechreport.com/2017/10/03/esi-audio-announces-moco-fully-passive-monitor-controller/
A-Designs Model "ATTY"/"ATTY2’D" (passive stereo/5.1 line-level attenuator/controller)
http://www.adesignsaudio.com/atty-stereo-attenuator
https://adesignsaudio.wordpress.com/products/atty2d-passive-line-level-control-5-1/
Vintagemaker "Little Knob" (balanced Monitoring Controller)
http://www.vintagemaker.net/littleknob.html
New Old Sound Inc. Model "McONE-B" (Balanced Passive Monitor Controller)
http://new-old-sound.com/products/31-mcone-b
https://www.musicstore.de/en_GB/GBP/New-Old-Sound-McONE-Monitorcontroller/art-REC0010844-000
SMPRO "Nano Patch+" Passive Stereo Controller
http://www.smproaudio.com/index.php/en/products/monitor-controllers/nano-patch-plus
http://www.smproaudio.com/index.php/en/products/monitor-controllers/nano-patch-plus#hi-res-pictures
http://www.smproaudio.com/images/products/monitorcontroller/nanopatch/Nano_Patch+_hires_2.jpg
JBL Nano Patch Plus
https://www.jbl.com/studio-monitor-controllers-accessories/NPATCH+BLK.html
https://www.thomann.de/de/jbl_nano_...hMIq5n_0LGy2QIVkYKyCh1XXgGREAAYASAAEgJp5fD_Bw
Radial Engineering Model "SAT-2" (Attenuator/Monitor Controller)
http://www.radialeng.com/sat2.php
https://www.thomann.de/de/radial_engineering_sat_2.htm
https://www.soundandrecording.de/eq...ring-sat-2-attenuator-und-monitor-controller/
LINEPaudio "A967" Audio Volume Control
https://www.chinabrands.com/item/dr...-xlr-rca-2160320-p.html?goods_id=299200&wid=1
https://www.aliexpress.com/item/201...-2-Channel-Volume-Controller/32836234829.html
https://www.ebay.de/itm/TECNICO-Bla...510467?hash=item41d0983603:g:D0IAAOSwgeBaW9hc
Sound Performance Lab (SPL) Model "Volume2" Stereo Volume Controller
https://spl.info/studio/volume-2/?lang=en
https://www.hhb.co.uk/product/spl-volume2/760/
Agent Audio Model Little Nelly/Solitare
http://www.agent-audio.com/index.php?page=products&subpage=littlenelly&lang=de
http://www.agent-audio.com/index.php?page=products&subpage=solitaire&lang=de
NF Audio Model MC10/RA10/Custom Monitor Controller
http://www.nfaudio.com/about-2
http://www.nfaudio.com/wp-content/uploads/396280_362557517105548_34947844_n.jpg
http://www.nfaudio.com/wp-content/uploads/425232_362553180439315_16570433_n.jpg
https://www.gearslutz.com/board/low...ob-vs-monitor-station-vs-msc1-vs-m-patch.html
Behringer Monitor 1
https://www.musictri.be/Categories/Behringer/Signal-Processors/Monitor-Controllers/MONITOR1/p/P0C9G
https://www.musicstore.de/de_DE/EUR/Behringer-Monitor-1/art-REC0013226-000?campaign=PSM/guenstiger
Audiolinear AXIS
http://audiolinear.co.uk/
http://audiolinear.co.uk/docs/Axis Monitoring Controller User Guide 2017v3.pdf
https://www.audiochocolate.com.au/spotlight-audiolinear-axis-passive-monitoring-controller/
Audio Innovations 1000 Passive
http://www.emporiumhifi.com/head-of...novations-1000-passive-preamplifier-upgraded/
https://www.cfc1962.it/recensioni/preamplificatori/audio-innovations-1000-line/
in use: source selector/Attenuator: unknown (bad quality tape-source toggle switch)
AUDIOPHONICS Volume Controller / Source Selector Alps 5 to 1 Black
https://www.audiophonics.fr/en/appa...ource-selector-alps-5-to-1-black-p-11789.html
in use: source selector/attenuator Alps SRRM/RK27
http://www.alps.com/prod/info/E/HTML/Switch/Rotary/SRRM/SRRM_list.html
IV. Low impedance versions (power attenuator)
Bugera PS1
http://www.musictri.be/Categories/Bugera/Guitar/Accessories/PS1/p/P0BV1
https://www.sweetwater.com/store/detail/PS1Atten
Harley Benton Power Attenuator
https://www.thomann.de/de/harley_benton_pa_100_power_attenuator.htm
https://en.audiofanzine.com/guitar-...enuator/medias/pictures/a.play,m.1354886.html
https://webcache.googleusercontent....rement-and-teardown+&cd=4&hl=de&ct=clnk&gl=de
Diy Power Attenuator
http://www.theguitarmagazine.com/diy/diy-workshop-build-your-own-attenuator/
V. Special Versions
Tortuga Audio - LDR3.V2 (digital controlled attenuator)
https://www.tortugaaudio.com/product/ldr3-v2-passive-preamp/
https://www.tortugaaudio.com/product/ldr3x-v2-1/
http://www.audiocircle.com/index.php?topic=132235.20
Tortuga Audio LDR3x DIY Preamp Controller w/ Remote
in use: source selector: Relais. Attenuator:
light dependent resistor (LDR) + digital controlled analog switch arrays -
check out also this URLs:
Lightspeed Attenuator a new passive preamp
Remote Controlled (RC) Volume Control Kits - Overview wanted
Passive Controller
Bespoke Audio
The Django preamp
CANARY AUDIO CA-200
AudioZone Pre-T1
Thel Passive Preamp
and post #135 under
Reel Audio PRM1
CANARY AUDIO P100
DALAUDIO PAS3/PV1
Little Baer MC2
Swissonic M-Control
OMNITRONIC VC-1
ESI AUDIO MOCO
JBL Nano Patch Plus
Behringer Monitor 1
Audiolinear AXIS
Bugera PS1
V. Special Versions
Hi tiefbassuebertr,
Why do you just post links? I don't understand your motivation for the time it takes.
-Chris
-Chris
Many integrated amplifier devices are basically completely worthless, because of the high repair efforts/costs at all switches in it's preamp sections (by rc controlled devices also the troubleshooting in MCU/st-by sections) - go toHi tiefbassuebertr,
-Chris
REPAIR BLOG - Amplifier Repair Services
Alps Rotary Switch Dropout Issues for Input Select (e.g. Onkyo, Yamaha, Creek)
for any few examples.
But one possibility always remains: bypassing the source selection without or with the volume control/attenuator potentiometer (sometimes disconnecting the MCU unit in case of remote controlled versions).
Both are then replaced by external components - either by only an input selector box, go to post #22 under
Rotary source selector for audio
or by a passive preamplifier.
A great improvement in sound was always noticeable to the users after realization of this thing.
Without such an overview, a choice is difficult and one tends then rather to replace the entire amp device with a new one, although the remaining parts of the old amplifier like power supply/power stage and sometimes the volume control are still flawless.
That's the main motivation for creating this line up.
BTW - various links are death after a short time. This is basically a disadvantage. But then you can check the links nevertheless in most cases by this portal:
Wayback Machine
my own website don't exist since any years - but you can check it while it's whole lifetime:
Wayback Machine
even useful for still exist websites for checking old models and their manuals of audio components - e. g.
Wayback Machine
Yes, but most people won't check more than two or three links at the most. When you post a huge list of links, much of your time is wasted.
Just saying.
-Chris
Just saying.
-Chris
to get a whole line up with as many existing models as possible the listings sometimes get longer although it is actually a hard-to-find kind of device.
In this respect it is not a waste of time.
If it had been an attempt to put all usual preamplifiers together in an overview,
it would indeed be a waste of time.
Now an other question:
I am looking for commercial available preamplifiers with only one stage as a clean current stage (unity gain) like a source-follower, emitter follower or in case of used tube cathode follower.
Such preamps I don't find.
Who can post some examples ?
P.S.: in post #1 under
Delivery Source wanted for this Cinch female Connectors in special Outline
you will find a diy version of such a preamp. The used circuit is based on Andrea Ciuffoli's power follower but with an IRF510 and only 9VDC supply voltage and therefore high idle current of 1A/channel - go to
the Power Folllower
This preamp bown away all top class commercial line preamps I know like e.g. Krell KBL, Pass Aleph P and Threshold FET series.
the Power Folllower
Joined 2009
Well, I find it very useful.😀
Thinking about change in my system, found this list of vendors and didn't
have to use Uncle Google 😉
Cheers!
Cheers!
In real live this is correct in most cases for most guys - but OTOH - to find out both best buy economic and the top quality units an extensive overview is essential which is nearly completely (in German we say "market overview").Yes, but most people won't check more than two or three links at the most. When you post a huge list of links, much of your time is wasted.
Just saying.
-Chris
Who now the type of used rotary switch in this at first glance interesting units from Aikido OTTO (Musik-Mate):
1) Input selector for phono-MM with low capacitance rotary switch:
https://www.ebay.de/itm/29497119391...0221&toolid=10044&customid=349308261204965492
2) passive preamp:
https://www.ebay.de/itm/294680167822?hash=item449c4e858e:g:N7cAAOSwBRdgOPW3
Best thanks for an advice.
Hmm, low capacitance doesn't matter below a certain point for one. Especially if you're switching current.
Look at it from an electronics circuit perspective, figure out what is really important for the situation. Grabbing for "the best" of whatever doesn't make sense and may not be the best for your application.
check out concerning the choice of right resistance for passive pre-amplifiers this thread:
https://www.diyaudio.com/community/...meter-as-a-passive-preamplifier.219342/page-8
You can't ignore the circuit impedance, and loading on what you are driving it with.
"Passive" control of volume level can be problematic, period. You can reduce s/n doing things that way (shocker eh?) and increase distortion of the source. It is an expedient and it functions, so it can get the job done, but not well. Keep in mind you are driving a shielded cable and also an input circuit that typically has RF filter capacitors in it. You need to drive that with a lower impedance.
How do you do that? With an active circuit. A competently designed circuit will have lower noise than a high impedance cable.
A switch and pot does not constitute a "preamp" people. Let's get the terminology right for starters. A switch and pot constitutes an input selector ... and a pot. It is not a preamp by any description, and will never present a low output impedance which is used to reject interference from outside signals. By the way, cable shielding is not perfect, it only attenuates interference and part of that equation is the output impedance of the signal source.
-Chris
-Chris
They are correct, but it greatly depends on the quality of the autoformer - which is in fact a transformer. Transformers are typically limited in frequency range and phase response (the weak link in transformer coupled amplifiers).
Thankfully the audio passband is normally pretty good. This depends entirely on the quality of the magnetics and winding. Therefore you can not generalize that these are a better way to go than a passive control - but a good one probably is.
A clean audio output stage is still your best bet ...
The whole idea of the intact audio AVC is that the quality of the core and winding is second to none.
They are expensive when compared to a potentiometer, of course. But people are mentioning 'high-end' stepped resistive attenuators like Goldpoint, and they're fairly expensive too.
- Goldpoint's 24-step stereo attenuator is $168 ($123 for blank switch/pcb combo, you buy the resistors). https://www.goldpt.com/prices.html
- intact audio's least expensive pre-wired stereo attenuator module is $400/pair - https://intactaudio.com/module.html
That's true in concept only. It remains to be seen that the construction and materials / design is the best. Meanwhile the cost of a very good pot and excellent active circuit is lower.
Hmmm, you tell me. The active circuit has huge advantages as well.
- Analog Line Level
- passive preamp
