No , that was meant in parallel to the speaker , but at the amplifier side before the cable .
I usually use around 100 ohms there unless I need to
develop a specific source impedance.
Yes, I have used 1k ohms in parallel with the speakerto keep the output at ground.
Thank you for the other values Papa. I have been simulating with a 10k pot sandwiched between 1.5k resistors. Will try with the new values.
Hi Mr Pass,
There are two capacitors on your diagram,one is output cap (1000uf) ,how about the other cap ?
both Fet can use IXTH6N50d2 ?
Hi Mr Pass,
I think
Left cap 1,000, output (right cap) 10,000. Although a lower right cap will be good, just acts like a first order crossover if too low.
I think
Yes. 😎
Yes. 😎
Thanks Mr Pass and Tea bag.
what is the V+ for this circuit ? can use exsiting V+ ? currently use 60V AC .
60 VAC would give approximately 80V rails... this is too much for the circuit with the transistor CCS. I would say it should be more like 30-40V.
Works perfectly . Just splitted back the PS into dual 30 V , with 2 bridges .
Lots of capacitance and completely quiet 😉
Dual Rail? That's not what the schematic looks like. Assume bottom Source connects to ground here, V+ only.😕 Nice work.
Dual Rail? That's not what the schematic looks like. .
no no single rail . 30 volts . I have a dual 25 V 500 watt transformer , and each secondarie has a bridge . Then the use was in series for the 60 volts , and dual mono 30volts, which I like a lot .
What is the drain voltage on the bottom FET? And the bias current?
The current is 1,6 amp , the voltage at the drain is half the rail .
Nice work, stephanobilliani, is the 5k a pot in your case? I wonder if this will work well with the R085's.
Schematic , how built . Should be all correct except for the naming of the D Fets ( Q1 and Q2 )and for C4 which is actually 10000uF 😉
Thanks Stefano. This is great!
Welcome ! 🙂 And yes , it's great indeed.
Though I think something is wrong . Becouse measuring voltage across C3 it look as it is " inverted " in polarity . Thats strange . I guess I am missing something ....
- Pass "DeLite" Amp from BAF
