Don't worry Werner; they dont have that sort of unorthodox stuff in Dublin...not even in Capel Street!
You are alright, I love Dublin
Tower Records Dublin Ireland
Wicklow Street!!! The largest Vinyl shop I have seen since 20 years
Guts Nächtle
Werner
There was a group buy ( not authorized by me but i tolerated it )...
Don't hold back Joachim.... ;-)
This is even better then teflon :
Omnicor: Vacuum capacitors
When we improve the Paradise even more NASA could take it to Mars.
Just posted my impressions on the VCaps here: http://www.diyaudio.com/forums/group-buys/224121-custom-11nf-32nf-v-cap-cu-tft-25.html#post3646370
Well, these caps are a gazillion times more expensive compared to Wima FKP2 which I had before, but if I am not totally mistaken there is a difference in sound, some improvement. Is it worth it? Well..... But I like them and will leave them in......
Can we take the supply voltage to 20kV and use color TV tubes for amplification?
My Paradise works so far!!
Wired the PSU first, than the Prereg, measured everything...all ok, than the Paradise..all fine. It's running now for 4 hours and all is stable.
Tomorrow I will give it a go and listen to it
Where do I put the earthcable of the turntable and where do I put the common earth of both channels together?
Butcher Plate?? We live vegetarian Mostly
Thanx Joachim, later I will give it a go... I left the Paradise on all night and day. Allways checking voltages, especially the 14,40V if they are ok. Thaat seems to be the fact. With open Input get it quit stable under around 40mV. With 10K it is around 0,2mV, that will be ok.
I'm very curious!!
I'm very curious!!
I'm very happy!!!
It sounds amazing!! Even my girlfriend was thrown away by the openess and dynamics of the sound.
The Paradise sounds very open, I hear things I never heard before and my Electrocompaniet is a very nice Preamp.
But it has quite some hum...sounds like 200Hz. And I think it is not that really quiet. But that doesn't bother me so much...it is much quieter than the recordsurface
Now listening to a lot of records and be very amazed...the next days I will have further investment about the hum...
Very nice, now GO LISTEN a bit, and then build a case (fast!)
Hey!!
thx for all the advice. Listening to this beautifull preamp was first priority. And Suzanne Vega for me is allways a good reference. (emotionally too...)
I solved the hum by removing the Paradise from the PSU. Also the hiss is gone. I had a 10k on the input for dc-measurement. These were some carbon ones, and they are not quiet.
The casing will take a while, looking at some options (actually one )
What dazzels me is the sheer detail of the Paradise. You can hear very deep into the soundstage. And it as a very nice warmth also. I have a feeling it sounds better now than in the beginning. The Caps and other stuff are forming. I'm asking myself where can the Calvin Buffer do any better?
- Analogue Source
- Paradise Builders
