Paradise Builders
Abraxas:
what about the heat of the Heatsink? Doesn't it cook the upper board? And what about the drift of the transistors...the upper board is exposed to much more heat...
Actually I was thinking to do it the way you did, because of footprint...but my thoughts went to the heatproblem, if it exists 😀
Another one built for a friend.
Time to leave phonostages for a bit. I've got a pair of Raal Tweeters that need integrating with my NS1000m's
Also, 26Vdc is the MINIMUM recommended input voltage for the PSU.[/QUOTE]
Hi Frans,
in a previous post it was stated that the input voltage have to be between 25 and 26 V. Now, you say minimum 26 and SQ have 28 V. That add quite some heat to the power transistors.
So, it's better with 26-27 volts?
Come on Alfred, why do you do that? we want the Calvin Buffer!
I could ask mild mannered Calvin´s alter ego Stupendous Man to take Buffers from Alfred send to me to a Blackforest mountain in a thunderous night and speak a stupendous motivation sermon.
Something like: Come on You little su***r. Get up and going, or I´ll have Your 6-lettered butt fried to a crispy crunch by the next lightning!" :bomb:
Well, if That doesn´t help ......
jauu
Calvin
jauu
Calvin
Hi Frans,
This has been discussed may times 🙂 the 26Vdc is the absolute minimum, different people have reported no improvements above this. Up to 28Vdc is allowable (each Volt adds 150mW dissipation) but be sure to have a well ventilated case. (Case not closed 🙂).
