PMA said:
Jung is quite right (at maximum), Curl does not show any relation to output power (or voltage swing).
True......i asked why, and got no response....
PMA said:And I should add - the positive slew and the negative slew should have the same speed.
True........easthetically pleasing.........
by what means do you ensure such symmetry in your designs..?
One of the reasons is too maintain very low distortion even at high frequencies
mrfeedback said:
Distortion at high frequencies is not so nearly as important.
0.1% distortion at 10kHz is inaudible.
Eric.
In case that you speak about 1-tone monaural sinus tone then I agree.
Pavel
Re: Re: Endless loops do me no good.
A fast, (>100V/uS), voltage-feedback driver.
peranders said:
What is the hardest thing to design: A fast driver or a amplifying output stage?
I'm in again. Couldn't help it.
Hi Nelson...
Compare figures 2 and 3 here:
http://www.national.com/an/AN/AN-261.pdf
...with the 'Alexander' amp.
Nelson Pass said:How does a 10 V/uS LH0101 qualify as fast, or are you just
playing with us?
- Output stages with gain Enhance Slew rate
