Re: Endless loops do me no good.
100V/us...with unity gain output stage rather difficult......if linearity is also to be of the first order...its possible however..
...400v/uS whole different order of things here....you would need to run your gain block in class AB...not elegant...in my view anyway...
But....as you may have noticed, i specifically recomended that the extra gain be generated before the unity gain output stage......by a complementary wilson mirror...
its parasitic capacitances are bootstrapped, making it easier to stabilise than a raw common emmiter stage at the output...
so...your concerns about instability in the output stage due to the extra gain are misplaced....
Sawzall said:
MikeK, to look at it another way, if you had the driver stage that had the 100 v/us, and the output stage was our humble emitter follower with its less than 1 gain. Would the amp not still have roughly the same slew rate without the stabilty issues that outputs with gain can have?
traderbam said:Lots of things have a "voltage transfer" close to unity into a loudspeaker load. Like a coil of wire or a relay or a forward-biased diode. Would you want to listen to your favourite musice through a forward biased diode?
I feel compelled to douse the slew rate debacle. For most loudness of music with typically efficient speakers, not much more than 5V/us is needed. We are debating a red herring.
...not if your mobile 'phone goes off.....
This statement just about sums up your capabilities as a designer. Still, at least the chairs on the deck will be tidy as the ship goes down....not if your mobile 'phone goes off.....
Re: Re: Re: Re: Re: Re: Slew rate etc
see:
http://www.anasoft.co.uk/EE/currentfeedbackmyth/currentfeedbackmyth.html
peranders said:
The MCP amp is a blueprint of the Alexander amp and yes, very much current feedback. The current comes from the current consumption of the opamp.
peranders said:I'm not sure what MCP is but I refered to the link under and Fred is right, the opamp is feedbacked conventionally but the overall feedback is about current.
The Marantz amp is also very much current feedback and the design is by the schoolbook.
Mike, if you don't agree on this I'll stop this yes-no war here.
see:
So...does your summery apply to Mr. Jonathan Carr?
http://diyaudio.com/forums/showthread.php?postid=205867#post205867
Wilson current mirror for gain?
Mike,
you said somewhere you propose to use a complementary Wilson mirror bias into class A to achieve the gain prior to the output stage proper. I have tried to find an actual schematic example in this thread, but gave up after re-reading half a dozen pages that contain mostly tedious fighting. Can you point me to an example?
If it was in the Electronics World paper, I erased that inadvertently. Would you mind resending?
Thanks,
Eric
Mike,
Thanks,
Eric
Re: Wilson current mirror for gain?
no wasn't in EW paper...for an example, see:
http://diyaudio.com/forums/showthread.php?postid=192255#post192255
capslock said:Mike,
Thanks,
Eric
Folks, I don't know whether I can help here, but: Please keep the slew rate above 50V/us. Trust me.
A follower can be a problem with difficult loads, because it has phase shift at very high frequencies. Still, a follower is the best compromise for a power amp.
mikek said:
Why?
Hugh's (user AKSA) point of view is quite the opposite but my is that the power amp should have have sufficient speed >50 kHz at full power.
AKSA55 is according to many very good despite of the low speed.
I have also a good feeling about speedy amps but the slew rate number must be put in relation to the output power.john curl said:Folks, I don't know whether I can help here, but: Please keep the slew rate above 50V/us. Trust me.
"quote:
Why?"
Jung suggests 0.5V/µS per peak volt of output, with a maximum of 2V/µS.
A typical 100W/8R amplifier has rails of ±55V (Adcom GFA545).
This would suggest a minimum of 28V/µS by Jung, john curl's recommendation looks to be halfway between the minimum and maximum of Jung.
Why?"
Hey, Peranders,
Not so fast!!
The AKSA uses 150MHz input stage, 100MHz Voltage Amp, 70MHz drivers and 30MHz outputs. It runs 1mA in the input stage, with very low lag compensation. It certainly isn't slow!
Hugh
Not so fast!!
Hugh
Hugh, I ment the result = power bandwidth, not the speed of each transistor.AKSA said:Hey, Peranders,
Not so fast!!
Wasn't the power bandwidth 30 kHz or so?
Hi Peranders,
Slew rate at full power is 12V/uS; not sure how to work out power bandwidth from this but I'm confident it's possible.
Hugh
Hugh
AKSA said:Hi Peranders,
Hugh
details here:
http://www.national.com/an/LB/LB-19.pdf
djk said:"quote:
Why?"
Jung is quite right (at maximum), Curl does not show any relation to output power (or voltage swing).
- Output stages with gain Enhance Slew rate
