PMA said:
Jung is quite right (at maximum), Curl does not show any relation to output power (or voltage swing).
True...
PMA said:And I should add - the positive slew and the negative slew should have the same speed.
True....
by what means do you ensure such symmetry in your designs..?
mikek said:
True......i asked why, and got no response..
True........easthetically pleasing......
One of the reasons is too maintain very low distortion even at high frequencies 😉
Symetrical slew rates are important, as is freedom from 'stiction' when coming out of clipping.
Distortion at high frequencies is not so nearly as important.
0.1% distortion at 10kHz is inaudible.
Eric.
Eric.
Eric.
In case that you speak about 1-tone monaural sinus tone then I agree.
Pavel
Re: Re: Endless loops do me no good.
A fast, (>100V/uS), voltage-feedback driver.
peranders said:
What is the hardest thing to design: A fast driver or a amplifying output stage?
I'm in again. Couldn't help it.
Hi Nelson...
Compare figures 2 and 3 here:
http://www.national.com/an/AN/AN-261.pdf
...with the 'Alexander' amp.
Nelson Pass said:How does a 10 V/uS LH0101 qualify as fast, or are you just
playing with us?
- Output stages with gain Enhance Slew rate
