Output inclusive compensation - What are the pitfalls?
I was leafing through Self's book and happened to come across the chapter about output inclusive compensation. It intrigued me, so I tried to try it on the amplifier I happened to have open in SPICE and it improved both phase margin and THD. The THD went from 0.00077% to 0.00035% (no, it's probably not an audible difference, but improving your numbers is fun!). More notably the decrease in THD was most pronounce on the third harmonic. This seems like evidence of Self's assertion than this semi-local feedback reduces cross-over distortion. All good stuff!
But what are the pitfalls? I can't remember seeing this technique being used that often. There must be a reason for that.
The compensation in question is made up of C6, C24 and R52. The amplifier is work in progress, so be nice. 🙂
The phase margin looks pretty nice!
Distortion without output inclusion. Notice the 3rd harmonic!
Reactions: lineup
Check out similar compensation in this amp:
From my experience, 2-pole compensation will give lower Thd, and better stability (E.g. phase margin), but it's more difficult to come up
with correct values for C and R.
One variation of 2-pole compensation have R going to the ground instead to the output, but using output gives better results.
I also remember somewhere on this forum an amp with 3-pole compensation..
And here is a random image that I saved on my PC long time ago, apparently I thought it was important 🙂
Reactions: njswede and lineup
This is 3-pole comp that was actually built:
C24 should be >> C6
For me this rule did not always work (see schematic at post #2). With C24 bigger than C6 Phase Margin was not acceptable...
I see i had a similar solution in 1976 as in post 2. It was a resistor from output in series with a capacitor to the base of the VAS transistor and a usual miller cab C - B.
In october 1984 i used exactly the described compensation and many times later. I have never thought of it as something special. Just a thing to try when the miller compensation affects the performance.
I just wonder if i had the idea or if it was in a magazine. In that case probably Wireless World.
Both amplifiers had ordinary Blameless topology.
Right, it is TMC.
In your schematic, C24 should be >> C6
I thought that consensus was the other way round, i.e. C6 > C24. C24 is the dominant pole. C6 can be in the range of five to ten times C24 then. The additional resistor R52 can be connected either to ground, the supply rail or the output. Which connection makes most sense depends on the amplifier topology. Some connections are bad for PSRR. If an amplifier has good PSRR with the resistor to ground, it can be connected to the output as well.
Reactions: minek123
Let me propose a better way.
C6 = C24.
There should be 2 resistors, 2K from the output, 2K from the ground.
PS: The single resistor version is just a simplified version. In this case of connecting from the output, the other resistor to the ground is infinity. Thus, C24 should be >> C6 to keep the voltage ratio about the same to avoid peaking at the frequency response. TMC should feedback about the same voltage amplitude before and after the "Transition".
I dont remember that i ever used so big miller capacitors. In a case like this i would begin trying with C6 = 10pF, C24= 100pF and R 10kohm.
A MOS input with much higher current usually makes the capacitors more equal to me.
If you replace T8 with a 2N7002 in cascode with Q12 you will get higher open loop gain. D3 stays of course. A resistor from D to E can function as a current limiter.
C6 = C24.
TPC has inherent peaking at some frequency in the closed loop response.
Setting both capacitors equal value reduces that peak indeed, but makes the dual pole concept very ineffective.
In order to gain appreciable advantage from TPC, the ratio needs to be at least five.
If you mind the unavoidable closed loop gain peak, better abandon TPC altogether.
Meanwhile I had a look at one of my books. In Douglas Self's book Audio Power Amplifier Design (6th edition) figure 13.16, you can see a correct example application with the correct capacitor ratio.
In Self's example, Cdom=120pF, the TPC capacitor has 1nF and the resistor 2k2.
A second resistor across the dominant pole capacitor can be used to get rid of the open loop gain peak.
While the open loop gain peak is considered inconsequential, it is probably better to remove it nonetheless.
Self chose 1.4Meg for the resistor in the example.
Reactions: minek123
I think that’s a different topology from what I’m attempting. Mine is a “output inclusive” or “transitional Miller Compnensation”, whereas the one you’re referring to is a two-pole compensation. I think Self sees them as two separate techniques. The latter doesn’t have any semi-local feedback/output inclusion.
Reactions: lineup
