OTA - One Transistor Amplifier
One more question!😉
In the attached Pathos TT output section's schem:
I know it use also a 120mH/1Rdc choke and the source voltage is on the inductor 3,25V (=3,25A).
How much is the gate voltage with the paralleled Fets? Need I calculate with 3*4V Vgs?
I think it is a good way to spread the heat between the Fets.
But than it is not an OTA amp anymore....
Greets:
Tyimo😀
The bias voltage remains the same no matter how many mosfets you put in //.
Using two mosfets instead of one might be a good idea, but more than two shouldn´t be necessary.
The mosfets might need to be matched, I used 5 x IRF540 in // once and one of them handled almost all the current even with 0,33R source resistors.
Use as few as you can get away with.
Tyimo said:
O.K. Mads! I wanted anyway to build the schematic with your style, to stay as close as possible to the original OTA amp. 😉
I would like only learn and understand how amps and different arrangements are working.
Tyimo
In that case, the input Z is the paralelled value of the impedances from gate to + and gate to gnd. 510K+100K//210K=156K but is varying with pot setting. Also, the psu ripple is injected directly into the signal :whazzat:
Tyimo said:
Mads!
Need I put a resistor before/between the inputcap and ground?
In the SEWA and OTA3.5 you did, but in the OTA7 not.
What value is the best?
What value need for the resistore befor the input cap to the ground?
Tyimo
It's only a bleeder resistor to discharge the input cap when the amp is turned off. This to prevent pops when you plug in signal cables. It is good practice to use it, but it is really superflous in a power amp. You should not plug in anything while the amp is on. Same thing with the output res. to gnd. It also changes the input Z ; In Z is the paralelled value of this resistor and the the res. from bias divider to gate.
Input cap low frequency rollof:
F=1/(2*pi*RC) Hz
for example 1uF and 100K=1/(2*3,14*100e3*1e-6)=1,6Hz
Same with output rolloff.
Thanks Mads! I understand!!:smash:
Back to your arrangement:
What is better for the voltage divider to use higher or lower resistore values? I mean from 24V to make 7V and if the input imp. resistore is independent from the voltage divider parts??
R1=510K R2=210K
or
R1=29K R2=12K ?
or even go down into the simple Ohm region?
Tyimo
R1=510K R2=210K
or
R1=29K R2=12K ?
Tyimo
Use divider values in the 10K-100K range 😉
Pre for OTA
Thanks Mads!
Here is something until that your BOSEWA will arrive.
I am a bit confused because in the useres manual there is max.15V output and in the service manual there is only 10V output.
What do you think is my PCB O.K.?
Tyimo
