Here are photos of the driver signals. Scope set at 2v/div and 20us
Both power supplies are not producing the same rail voltage. The lower supply rail voltage is +/-23.0v. Upper power supply rail voltage is +/- 4.09v.
Yes, only the one supply is heating up, the one with low rail voltage.
The hot supply is also the one with the new rectifiers.
Two things I do have, is a really good soldering station and a really good de-soldering station.
Disconnected the red and black wires that connect the hot supply to the audio circuit. DC rail voltage on that side jumped up to +/-32.5v. Current draw across my limiter dropped from +4.57v down to +2.0v DC.
I should have been more clear.
You will leave the 3 parallel 6 ohm resistors in the B+ line.
You would solder the black wire between the output of the second power supply back into place.
You would insert the 120v lamp in-between the solder pad for the red wire and the red wire for the second power supply.
I did that.
Also just found I have no voltage on any of the three legs of the voltage regulator circled in the attached photo. It is next to the one that didn't have voltage before. That is the photo I used before, with the old resistors in place.
- General Interest
- Car Audio
- Orion HCCA 2100 no rail voltage.
