Options with lucky little collection of high-end drivers
Joined 2008
I was fortunate to pick up a little collection of very nice tweeters and mids this morning, along with a bunch of quality crossover parts. Plus a pair of the clone Proac 2.5 speakers that were popular in the early oughts (external crossovers and a broken tweeter).
I think I will reason through the Proac clones and see if I can get them working.
The big options are with the following drivers (pair of each)
My simple ideas are to build a couple smallish two-ways: Focal/Seas speaker and Accuton speaker. Maybe try the unknown 5” mids with the Seas, too. Mock up something in XPS and foamcore first, use MiniDSP or something like Zoudio to play with crossovers, then maybe go all in with passive crossovers with all the good caps, coils, and resistors I picked up. After tons of measurements and tweaking.
First questions:
  1. Where can I get data sheets for these older Accutons? I was only able to find an archive pdf of an old Madisound catalog with them listed (attached pics below).
  2. Is anyone familiar with Audiotechnology drivers enough to know the difference between their 5” models?
  3. Are the Accuton or Focal mids conducive to a MLTL alignment? Anyone willing to run some models for me?
Thanks for humoring me as I rub my hands together imagining what I could do with expensive drivers that I never would have purchased first hand.
I’m thinking that small monitors + a sub or two would be easiest, but I’m also open to suggestions. I have relatively small rooms, so I don’t think massive three-way speakers are in the cards. But I could see a small tower working. I have a mix of amps and preamps available, plus a nice 6-channel passive attenuator (Yamaha MVS-1) that could be incorporated.
This long post is all to say what would you do with these drivers?
Thanks for your thoughts and ideas!
The ceramic speakers are extremely difficult to implement. Some German magazine (Klang und Ton) tried it and they gave up, even having all the gear and a damped chamber for measurements.
Also without proper Woofers no bass can be reproduced.
My advice sell them and get a good proven kit for the money.
I don't understand why ceramic drivers would be that difficult to use. No different to metal drivers I would have thought?
Joined 2008
Thanks, everyone. So bass support will definitely be needed, with subs or in 3-way.
With the Accutons, it looks like I could cross them at 3k and add a notch or two to the mid breakups.
For the others, the Focal is so sensitive, it looks like it would better fit with a compression driver above it in a 3-way. With the Seas, I could cross anywhere between 2-4K and with level matching be in good shape relatively easily.
I will contact audiotechnology to see if I can get data on the other mids.
Joined 2008
The unknown mids are likely an early version of this driver:
Flexunits 4 H 52 06 13
Looks quite capable as a midbass for a small monitor speaker. Possible transmission line loading for low end extension?
I also found impedance curves for the Accutons in the way back machine. They look pretty benign. Multiple accounts here and elsewhere say a notch is a good idea @~3.8k for the tweeter. But it looks like it could be crossed lower…
I need to get a 2-way crossover test rig up ASAP. :D
Joined 2008
Bumping this open-ended thread with my latest idea.
B&C DE360 on ME20 Waveguides https://www.parts-express.com/pedocs/specs/294-6042--bc-de360-spec-sheet.pdf
Focal Audiom 7 A2 https://site.diy-loudspeakers.com/...t_focal_drivers/FOCAL_MIDRANGE_AUDIOM_7A2.pdf
For bass, I’m considering
Peerless P830869 https://www.parts-express.com/pedocs/specs/264-1098--tymphany-hds-p830869-spec-sheet.pdf
Or
Dayton RS225P-8 https://www.parts-express.com/pedoc...rs225p-8a-reference-series-specifications.pdf
Any opinions on choosing between those woofers?
I expect to cross the woofer-mid at ~300 and the mid-tweet at ~3K. I like the idea of highlighting this fancy mid for as much of the spectrum as possible. I could call them 3^3. :D
I’d like to figure out a TL for the woofer (like xrk’s RS225 FAST), but that will likely take a while, so I’ll shoot for a prototype ported box at first. Separate box for the mid. Prototyping will be with XPS, possibly skinned with thin ply or HDF. And I can use the woofer box with prototyping of those other fancy drivers at the beginning of this thread!
Any pointers to keep in mind? I’m going to reacquaint myself with Xsim and maybe figure out that recent TL software…
August will be speaker month. :cool:
Joined 2008
Continuing with doing everything possible without actually acting on it…
I think I like the looks of the RS225P better than the Peerless in my expertly rendered concept. :p
I believe the Peerless could go lower, sealed or ported, however.
Joined 2008
Constrained layers of silliness. I don’t know if this is going to work, but I’m going to try.
My cuts are awful, yet hidden. :D
