Here are the parameters I measured of the OPT:
Primary DCR: 115R
Primary Inductance: 39H - 25Hz
Primary Capacitance: 2.7nF - 1Khz
Leakage Inductance: 18mH - 100Hz
Primary DCR: 115R
Hi
Regarding the freq. answer I see more than 0,5 dB of variation.
Have you check the response at the end of 240 kohm resistor on grid of 300B?
Check the impedance of the probe of the test set.
If it is linear you can exclude te circuit, first of all
Then read the backward method to test only the trafo
Walter
Walter
this is the result i measured at the grid 300B
Can you explain the test set? which generator and analyzer you use?
Try to measure the test signal comes from generator
Then, if you have a ss amp try to measure as described the OT only; it is not complicated
Walter
Walter
Walter
I Use keysight edux1002g
Primary DCR: 115R
Leakage Inductance: 18mH - 100Hz ----- too tall ???
Primary DCR: 115R
when i test the frequency. i hear hissing from OPT starting at 1Khz
Do you think due to the wire loops vibrating.
here is the OPT spec I made: 3K5 - 8R - 300B
EI 96 x 50 - 32 x 50 mm
P: 2160T - 0.3mm
S: 105T - 0.45mmx3
4S + 3P
S-S, P-P: 0.05mm PET
P-S 0.4mm Paper
P: 2160T - 0.3mm
S: 105T - 0.45mmx3
4S + 3P
P-S 0.4mm Paper
The 39H a little unbelievable, this range is the 10k transformers territory.
With these "measured" OPT parameters the estimated OPT frequency range is -3dB 4.5Hz...32kHz.
If it not correspond with the screenshots the parameters are not completely correct.
If you test the amp with 10kHz square wave, the suspected resonance within the audio band would be more visible.
BTW the screenshot in the #203 post has similar tendency (with lesser gain) of FR than the output so the boost partially due the previous stages.
Try to measure FR on the grid of both stages.
i made measurement at 1Khz and 10Khz with square wave.
By looking at the 10kHz square wave measurement, it is pretty good. The frequency response should be much better than the one you measured
Are the 10kHz square wave measurement measured under the same conditions as with the frequency response conditions?
I ask to describe the test set, which equipment are used
The range of dB on firsts freq. response are different from the lasts
And the response taken on grid of 300B is linear
Walter
Walter
below is the result i did it again.
10Khz square wave after OPT load 8R
10Khz square wave at 300B . grid
And the measurement results after OPT and at grid 300B.
- Tubes / Valves
- OPT Characterization
